CyberAngel Posted January 29, 2018 Posted January 29, 2018 The .19 dimension (bottom right) should run horizontally, not vertically. Those isometric dimensions are hard to get right. Quote
CyberAngel Posted January 29, 2018 Posted January 29, 2018 basty said: I can't see the Properties palette. Where is it? You should be able to select the dimension object, right click, and find Properties on the menu that appears. I keep my Properties windows docked on the left side. It's easier than opening and closing it all the time. Quote
ReMark Posted January 29, 2018 Posted January 29, 2018 basty: Perhaps a Basic AutoCAD course might do you some good. View tab > Palettes panel > Properties icon or input the command Properties at the command line and press the Enter key. Quote
basty Posted January 29, 2018 Author Posted January 29, 2018 ReMark said: basty: Perhaps a Basic AutoCAD course might do you some good. View tab > Palettes panel > Properties icon or input the command Properties at the command line and press the Enter key. Where is this View tab located? Don't forget that I am using AutoCAD 2014 in classic mode. This is the Properties palette I get (see below image) by selecting the dimension > right click on it > then choose Properties. There is no "oblique" option in the Properties of mine. Quote
Cad64 Posted January 29, 2018 Posted January 29, 2018 Basty, look at the top of your properties panel where it says "No Selection". You need to have something selected in order to view its properties. Maybe you should take ReMark's advice and take a basic Autocad course. Quote
ReMark Posted January 29, 2018 Posted January 29, 2018 basty: In Classic you should still be able to enter the Properties command at the keyboard. And yes, you must select an object first in order to check its properties. I failed to mention that. Quote
basty Posted January 29, 2018 Author Posted January 29, 2018 ReMark said: basty: In Classic you should still be able to enter the Properties command at the keyboard. And yes, you must select an object first in order to check its properties. I failed to mention that. See below video. I think I already follow your instruction correctly. I still can't find the "oblique" option in my Properties palette. Why don't you just tell me how to edit the text by a command as I asked in post #19?? https://screencast-o-matic.com/watch/cFVUD5ovFQ Quote
ReMark Posted January 29, 2018 Posted January 29, 2018 Grrrrr. Edit regular text or dimension text? Quote
Cad64 Posted January 29, 2018 Posted January 29, 2018 basty said: See below video. I think I already follow your instruction correctly. I still can't find the "oblique" option in my Properties palette. I watched your video and something is wrong. When you select a dimension and open your properties palette, you should see all the properties for the selected dimension. Your properties palette shows no dimension properties. It seems that Autocad is not recognizing your selection. Take a look at this article. If the PICKFIRST variable does not solve the problem, you may need to repair or reinstall Autocad: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Properties-of-selected-object-not-displayed-in-Object-Properties-toolbar.html Quote
scj Posted January 29, 2018 Posted January 29, 2018 Before dimensioning you could set the corresponding UCS Regards Jochen http://www.ant-ares.de DIM_scj.dwgFetching info... Quote
basty Posted January 30, 2018 Author Posted January 30, 2018 (edited) ReMark said: Grrrrr. Edit regular text or dimension text? I want to edit the dimension text so that it look like this: How to do it? Edited January 30, 2018 by basty Quote
basty Posted January 30, 2018 Author Posted January 30, 2018 Why do I find myself being ignored? Quote
Cad64 Posted January 30, 2018 Posted January 30, 2018 basty said: Why do I find myself being ignored? Hmmmmmm, good question. Did you read my last post or am I being ignored? You have bigger problems than just trying to figure out how to dimension an isometric drawing. There is something wrong with your program and I strongly recommend that you address this issue. Quote
basty Posted January 31, 2018 Author Posted January 31, 2018 (edited) Cad64 said: Hmmmmmm, good question. Did you read my last post or am I being ignored? You have bigger problems than just trying to figure out how to dimension an isometric drawing. There is something wrong with your program and I strongly recommend that you address this issue. I can do an aligned 2D isometric dimension. Now how do I create a dimension like the 0.5R (see below) in 2D isometric drawing? And this too: Please somebody answer my question. Edited January 31, 2018 by basty Quote
Cad64 Posted January 31, 2018 Posted January 31, 2018 Since you quoted me, I will respond. I don't do isometric drawings. If I needed to create a drawing like this, as I mentioned before, I would first create a 3D model. Then I would be able to align my UCS with the various faces in order to easily dimension the model. Since I don't do isometric drawings, I'm not sure how to dimension a drawing like this, and I'm really not interested in spending a lot of time trying to figure it out. As far as I'm concerned, this is the old way of doing things, and I'm not interested in going backwards. So, unless you want to discuss the issues with your program that I alerted you to previously, I really don't have anything else to add to this thread. Also, you might want to take a minute and say thank you to everyone who has offered assistance in this thread. The reason why no one is responding anymore could be a result of your apparent lack of gratitude. We don't get paid to be here, so "Please" and "Thank You" go a long way. Nobody likes feeling as though they are being taken for granted. Just a thought. Quote
basty Posted January 31, 2018 Author Posted January 31, 2018 Yes of course, thank you everyone. Cheers. Quote
ReMark Posted January 31, 2018 Posted January 31, 2018 The .50R that you refer to and the leaders with corresponding text the red arrow points to are most likely text objects. I thought you figured out how to create isometric text already. Quote
basty Posted January 31, 2018 Author Posted January 31, 2018 (edited) ReMark said: The .50R that you refer to and the leaders with corresponding text the red arrow points to are most likely text objects. I thought you figured out how to create isometric text already. I can create a dimension such as .50R. The next question is, what is mean by this (see below)? It says two diameters, one is ∅.625 and other ∅.623. But it point to a single circle. Which diameter I should use? I am confuse. Edited January 31, 2018 by basty Quote
Cad64 Posted January 31, 2018 Posted January 31, 2018 basty said: The next question is, what is mean by this (see below)? It says two diameters, one is ∅.625 and other ∅.623. But it point to a single circle. Which diameter I should use? I am confuse. That is a tolerance dimension. It tells the machinist that the hole diameter can be a minimum of 0.623 to a maximum of 0.625. Quote
ReMark Posted January 31, 2018 Posted January 31, 2018 Maybe you should invest in a copy of the Machinery's Handbook by Eric Oberg. "Machinery's Handbook for machine shop and drafting-room; a reference book on machine design and shop practice for the mechanical engineer, draftsman, toolmaker, and machinist is a classic reference work ..." Quote
