jes_g Posted January 26, 2018 Posted January 26, 2018 (edited) Hi all, I have a layer consisting of 30k block references. I want to export the properties of all these block references into Excel sheet or txt. Does anyone know a LISP routine to do this? The sample drawing is attached with this thread Thank you in advance. Best wishes, Jes G Sample.dwgFetching info... Edited January 29, 2018 by jes_g Quote
jes_g Posted January 28, 2018 Author Posted January 28, 2018 ronjonp said: DATAEXTRACTION Thank you. I tried this command. But it doesn't export all properties. Attached is the screenshot showing the properties that have not been exported (marked as red) Quote
jes_g Posted January 28, 2018 Author Posted January 28, 2018 ronjonp said: DATAEXTRACTION https://ibb.co/nRtsjG Quote
devitg Posted January 28, 2018 Posted January 28, 2018 Please upload a Sample.DWG with at least a few block's references Quote
jes_g Posted January 28, 2018 Author Posted January 28, 2018 devitg said: Please upload a Sample.DWG with at least a few block's references Thank you for your response. The sample drawing is provided below. https://drive.google.com/file/d/1bLurrxbnH6c9Fee5L4qIc0okwdVU0b9W/view Quote
devitg Posted January 28, 2018 Posted January 28, 2018 Please give what property you need to see Quote
jes_g Posted January 28, 2018 Author Posted January 28, 2018 devitg said: Please give what property you need to see SeriaNo https://ibb.co/i323Rw Quote
SLW210 Posted January 29, 2018 Posted January 29, 2018 Can you post the drawing and images directly to CADTutor? Quote
BIGAL Posted January 30, 2018 Posted January 30, 2018 DWG is 2017 or 2018 I am a bit lazy and have to open anothe version, BUT OD: normally means it has object data and is extracted in a different way than normal Autocad data. Google Object data Autocad. It does appear in properties. Quote
Roy_043 Posted January 30, 2018 Posted January 30, 2018 The OP's file contains proxy objects. So you may need more than 'Vanilla' AutoCAD to extract the required data. Quote
jes_g Posted January 30, 2018 Author Posted January 30, 2018 BIGAL said: DWG is 2017 or 2018 I am a bit lazy and have to open anothe version, BUT OD: normally means it has object data and is extracted in a different way than normal Autocad data. Google Object data Autocad. It does appear in properties. Thank you, BIGAL. The problem is solved using this Quote
