Can anyone show me with an screencast how to create vb file & run the code
Private Sub CommandButtonSmooth_Click()
Dim sset As AcadSelectionSet
Dim v(0) As Variant
Dim lifiltertype(0) As Integer
Dim plineObj As AcadLWPolyline
Dim oLWP As AcadLWPolyline
Dim i As Long
Dim var As Variant
Dim oSS() As AcadEntity
Dim oGr As AcadGroup
Set oGr = ThisDrawing.Groups.Add("QWERT")
Set sset = Nothing
For i = 0 To ThisDrawing.SelectionSets.Count - 1
Set sset = ThisDrawing.SelectionSets.Item(i)
If sset.Name = "ss1" Then
sset.Clear
Exit For
Else
Set sset = Nothing
End If
Next i
If sset Is Nothing Then
Set sset = ThisDrawing.SelectionSets.Add("ss1")
End If
'create a selection set of all the entities on a given layer
'here they are all lw polylines
lifiltertype(0) = 8
v(0) = "jhl_9.25_begin"
sset.Select acSelectionSetAll, , , lifiltertype, v
ReDim Preserve oSS(0 To sset.Count - 1) As AcadEntity
For i = 0 To sset.Count - 1
Set oSS(i) = sset.Item(i)
Next i
'add plines to group
oGr.AppendItems oSS
Dim GRname As String
GRname = oGr.Name
' using SendCommand method with Group
ThisDrawing.SendCommand "_PEDIT" & vbCr & "M" & vbCr & "G" & vbCr & GRname & vbCr & vbCr & "J" & vbCr & "0.0" & vbCr & vbCr
' deleting group and clearing selection set
oGr.Delete
sset.Clear
'start to pedit spline or fit here
Dim oGroup As AcadGroup
Set oGroup = ThisDrawing.Groups.Add("ZERO")
GRname = oGroup.Name
'select all the joined plines
ReDim Preserve oSS(0) As AcadEntity
Set oLWP = sset.Item(i)
Set oSS(0) = sset.Item(i)
'create group with one item
oGroup.AppendItems oSS
If oLWP.Closed Then
'Spline
ThisDrawing.SendCommand "_PEDIT" & vbCr & "M" & vbCr & "G" & vbCr & GRname & vbCr & vbCr & "S" & vbCr & vbCr
Else
'Fit
ThisDrawing.SendCommand "_PEDIT" & vbCr & "M" & vbCr & "G" & vbCr & GRname & vbCr & vbCr & "F" & vbCr & vbCr
End If
'remove the pline from the group
oGroup.RemoveItems oSS
Next i
sset.Delete
oGroup.Delete
End Sub
Approved VB code for Joining lwpolylines
Just type VBAMAN, NEW, pick ACADproject, "Visual basic editor", "This drawing", then paste code into "Code" "Run"
It's ask Macro name
5N0a6jm
thanks
Siva
You need to understand what the VBA code is doing on how it expects to be run "CommandButtonSmooth_Click() I am pretty sure comes from using the mouse to start it. I am no VBA expert. Once you ahve the code you can save it and you can load it from the command line at any time. An example I would type this (vl-vbaload "P:/AutoDESK/VBA/myvbatestcode.dvb")(vl-vbarun "Test") and it will run your code.
now
Private Sub test()
