Hi,
I have a problem that I have many drawings which contain number of the same block which should be hide. Based on tips from another threads I came up the following solution which I don't know how to utilize.
First -> I use lisp which create new layer, then blocks with the same name are moved to this layer. For example something like this:
(vl-load-com) ;Load VLisp extensions
;; Function to change bllocks to a layer by wildcard
(defun Blk2Lay (LName ss / n en eo)
 (if (not (tblobjname "LAYER" LName)) ;Check if layer doesn't exist
   (command "._LAYER" "_Make" LName "") ;Make the layer
 ) ;_ end of if
 (setq n (sslength ss)) ;Initialize counter
 (while (>= (setq n (1- n)) 0) ;Step through all entities in selection set
   (setq en (ssname ss n) ;Get the nth EName
         eo (vlax-ename->vla-object en) ;Get the ActiveX object
   ) ;_ end of setq
   (vla-put-Layer eo LName) ;Change block reference to new layer
 ) ;_ end of while
) ;_ end of defun
;; Command to change blocks to a layer by wildcard
(defun c:Blk2Lay (/ LName BWild ss)
 (if (setq LName (getstring "Enter the layer's name: ")) ;Get the layer's name
   (if (and
         (or
           (and (= (setq BWild (getstring ;Get wildcard, default as layer name
                                 (strcat "Enter the wildcard for the block name <*" LName "*>: ")
                               ) ;_ end of getstring
                   ) ;_ end of setq
                ) ;_ end of =
                (setq BWild (strcat "*" LName "*")) ;Default to LName
           ) ;_ end of and
           (and BWild (/= BWild ""))
         ) ;_ end of or
         (setq ss (ssget "_X" (list '(0 . "INSERT") (cons 2 BWild)))) ;And some blocks found
       ) ;_ end of and
     (Blk2Lay LName ss) ;Perform the change
   ) ;_ end of if
 ) ;_ end of if
) ;_ end of defun
Second - > I changed property of this layer to non visible.
Third - > I applied above changes on selected drawings.
Based on another example I found that there is possible to use LISP getfiles as well as ObjectDBX Wrapper which allow to use another function like below:
//This is example of script which remove blocks with name "KOLKO' from selected drawings
(defun c:dbtest ( / lst )
   (if (setq lst (LM:getfiles "Select Drawings to Process" nil "dwg;dws;dwt"))
       (LM:odbx '(lambda ( doc ) (LM:deleteblocks doc '("KOLKO"))) lst t)
       (princ "\n*Cancel*")
Can anyone help me how I can solve my problem?
Edited by SLW210
Added Code Tags!
Will the "hidden" layer be turned off or will it be frozen?
It doesn't matter in this case. They may be hidden or frozen. I just wanna keep these blocks, but not remove them
I think it would make a difference. You might want to provide a sample drawing for anyone who wishes to help you to test their code against. Be specific about which blocks must be "hidden" and the method you prefer. We'll need a .dwg file not an image file.
Right now I can only try to explain my problem more in detail using examples which are comparable to my primary ones. Of course number of drawings in my case is much more bigger.
Example. I have three drawings - lets assume:
1.dwg - 2 obejcts of the same block named "KOLKO" which are on 0 layer. For example, block represents circle put somewhere two times.
2.dwg - 1 object of the block named "KOLKO" - 0 layer.
3.dwg - 5 objects of the block named " - 0 layer.
Another objects if they exist, don't care me. Now I open file 1.dwg and I want to move all objects of block "KOLKO" to the new layer, for example TEST, and set this layer as hidden. And without opening another drawing repeat this action.
Using LISP http://www.lee-mac.com/getfilesdialog.html I can choose which drawings should be applied (in this example 1.dwg, 2.dwg, 3.dwg). Then using LISPhttp://www.lee-mac.com/odbxbase.html I want to utilize script (code showed in first post) which allows to create new layer and select, by name of the block, objects which will be moved. Unfortunately I don't know also how to change layer property on hidden option.
Maybe there is easier way to do it becuase I saw scirpt which allow move all object of the block to another layer by selecting one of them. But there is a constrain that destination layer must exists in all drawings. But it's not a problem becuase I know how to do it in another way without need to use LISP to change layer on hidden. But still I don't know how to apply particular scipt on all selected drawings, using this LISPhttp://www.lee-mac.com/odbxbase.html
I am not familiar with LISP so this is a reason why it is hard to me find out how it works :/
A simple layer situation (command "-layer" "off" layername "") or freeze. Wildcards can be used also -layer off k*
