Pander93 Posted January 16, 2018 Share Posted January 16, 2018 I made a Block Library with 4 objects in it, which I proceeded to insert into a drawing. However, only 2/4 of the objects inserted. The layers are not frozen, locked, or invisible. I've attached two screenshots. Please help me! I've been messing with this for hours. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted January 17, 2018 Share Posted January 17, 2018 Can you post the .dwg? Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 17, 2018 Share Posted January 17, 2018 Did you try a Zoom > Extents? Perhaps the block insert point was far removed from the actual block itself. Quote Link to comment Share on other sites More sharing options...
Pander93 Posted January 17, 2018 Author Share Posted January 17, 2018 Wow, it was there. I can't believe I didn't try that. Any idea how it became so far removed from the other blocks in the block library? They were designed in a specific order and proximity, but two of them ended up in two different places, extremely far away, while the other two were placed where I expected. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 17, 2018 Share Posted January 17, 2018 Someone (not you of course) decided that the basepoint for each block was going to be something other than right on the block itself. It could even be 0,0 but the block entities could have been meters or miles away from 0,0 when WBLOCK was invoked. FYI - always try the obvious first. Quote Link to comment Share on other sites More sharing options...
Pander93 Posted January 17, 2018 Author Share Posted January 17, 2018 It's strange because whenever I upload the block library into other drawings, it's exactly as I expect. Anyhow - thanks for your help. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 17, 2018 Share Posted January 17, 2018 The CAD gods work in mysterious ways. Not for me to explain why. Glad you found what you were looking for. You're entirely welcomed. Quote Link to comment Share on other sites More sharing options...
