neuri Posted January 7, 2018 Posted January 7, 2018 As in the drawing, i'm trying to create a Stretch downwards(Distance 2) while at the same time having the 2 lines inside the door stretch accordingly but i can't seem to do it, i either get 1 line to stretch or none. I tried the Fix and Equal constraints, didn't really work or maybe i'm doing it wrong. Anyone know how? The stretch to the right(Distance 1) works fine. Quote
iconeo Posted January 9, 2018 Posted January 9, 2018 Please post block, I believe you need a to add a move action to the Distance2 and set it's multiplier to 0.5. Thanks. Quote
steven-g Posted January 9, 2018 Posted January 9, 2018 Without seeing what you want to do it is just guesswork (we can't see what is selected with the actions in an image - and neither can we see the selection area boxes), but I would guess that you mean the two diagonal lines leaving the lines centered on the door. the bottom of the lower diagonal wants to be included with all the objects at the bottom of the door in the stretch action, you then need to create a separate stretch action just selecting the ends of both lines where they meet at the middle of the door and give this a multiplier of 0.5 in the properties palette. Quote
iconeo Posted January 9, 2018 Posted January 9, 2018 Without seeing what you want to do it is just guesswork (we can't see what is selected with the actions in an image - and neither can we see the selection area boxes), but I would guess that you mean the two diagonal lines leaving the lines centered on the door. the bottom of the lower diagonal wants to be included with all the objects at the bottom of the door in the stretch action, you then need to create a separate stretch action just selecting the ends of both lines where they meet at the middle of the door and give this a multiplier of 0.5 in the properties palette. Stephen is right, I meant to say stretch in my post not move. Oooops. Quote
neuri Posted January 9, 2018 Author Posted January 9, 2018 I don't have the file with me now but i'll try it out. Also, why doesn't LT have constraints Quote
BIGAL Posted January 10, 2018 Posted January 10, 2018 (edited) The 999 question why doesn't LT have it ! Edited January 11, 2018 by BIGAL Quote
