Hi everybody;
I need the "position id number box" to be related to the corresponding member using two straight lines. I explianed the steps in detail in the attached autocad file. It would be great if you can help me on this matter.
Thanks in advance.
QLeader.dwg
Thank you for the suggestion.
It helps me a bit but we have so many members that it becomes impractical to use that option. I wonder if it would be possible to generate a code so that i can achieve what i need that i described in my first post.
Not sure what you're asking for. If it's a lisp to modify qleader settings to draw the leader by picking two points that's easily done calling qlset.lsp by Frank Whaley at Autodesk which you can search for in this Forum. Numbering and adding those outlines would be more work.
