Hello.
Is there a settings I'm missing that would allow no change in resolution of polygons when switching from 2D to 3D shade mode?
Right now it looks like this:
2D:
3D:
In Acad Display Resolution settings I've tried put everything to the max possible, it seems only affect 2D view. Also tried change whiparc to 1.
I've tried change 3D Graphic System Configuration from software to wopengl7.hdi - still nothing.
Anything else I could try?
Thank you.
P.S.
Using Autocad 2002 on Windows 7 32bit
Given that you are using AutoCAD 2002 why don't I see a mention of the VIEWRES system variable?
Is Shademode set to 2dwireframe?
... why don't I see a mention of the VIEWRES system variable?
I thought that is what OP meant by "In Acad Display Resolution settings I've tried put everything to the max possible"
What happens if you copy everything to a new drawing?
