Hi All,
i am having problem with autocad printing. Recently i got a drawing made by our manufacturers. While viewing the drawing in model, i can see the objects clearing. But while printing the objects are coming much thicker that we are not able to differentiate the light nodes. Please someone help me. am posting the pictures of the same.
Post a dwg.
The model does not seem to have the colour set, are you plotting from a layout and have reset all the layer colours and linetypes for that layout, would explain thick circles.
yes am printing from layout. i just tried printing from model. Its printing properly. i want to print it from layout itself, as all the viewports and title block is set in layout. Can you help me
Did someone assign a lineweight to the layers in the Layer Properties Manager?
Switch to Model Space in the Viewport, to check for lineweight overrides in the Layer Manager as that would explain the lineweights plotting different on that Layout than the Model tab.
Like every one open up layer manager and scroll to right you will see VPcolor which can be different to Model color.
