cadmando2 Posted January 16, 2009 Posted January 16, 2009 I was working away and just before I was getting readly to print when I found that my arrows where not filled. I check the arrowheads and it is set to "closed filled. and the text is ok. I have had this happen before but the text was the same way. how can I fix this? Quote
brawleyman Posted January 16, 2009 Posted January 16, 2009 When you invoke your quick leader command, push "S" for settings and see what your leader arrow is set to. Sometimes, when I open a drawing that someone else has worked on, it is changed manually instead of changing it in the dimension style. Seems that they are being overridden by something like that. Hope it helps. Quote
cadmando2 Posted January 16, 2009 Author Posted January 16, 2009 I'm using AutoCAD 2008 and have not used the leader command all day. I check my setting and there fine. I even to the time to compare with another drawing and setvar's and couldn't find any thing. I mit of over looked something. working on a dead line and have not had time to realy at the time to look. just thought someone has had the same thing happen to them. But it is happen to solid arrow? So it couldn't be a leader line setting. see drawing Quote
cadmando2 Posted January 16, 2009 Author Posted January 16, 2009 The was the veriable fillmode! Quote
ajtat411 Posted February 11, 2009 Posted February 11, 2009 The was the veriable fillmode! I'm having a similar problem, except the whole arrow doesn't show up. This happens with dimensions. The leader arrows are fine, but dimension arrows that are "closed fill" do not show up. When I switch to a "open fill" arrow type, it shows up fine. The arrow size is not the problem. Any sugguestions? Quote
GliderRider Posted February 19, 2009 Posted February 19, 2009 I'm having the same problem. Arrows are set to closed fill, but don't show up. Don't show up in the preview of the dims either. Other styles work ok, but I need closed fill. Quote
wannabe Posted February 19, 2009 Posted February 19, 2009 Dim arrows need a dimension length to be a minimum value before they show. Not saying it applies here, probably not considering other termination symbols appear fine. But what happens if you place a leader with a huge distance between the first two points? Long shot... Quote
sscovill Posted January 23, 2014 Posted January 23, 2014 try tools>options>display tab>display performance> check Apply Solid Fill Quote
YoungIndustry Posted June 8, 2014 Posted June 8, 2014 i guess you are in hidden view style... if its true,as my exprience its imposibble to plot a closed fill arrow head in a hidden viewstyle...try to use another style and the closed arrow will appear.... Quote
"Mitch" Posted January 22, 2018 Posted January 22, 2018 If your FILLMODE is set to "0", it must be set to "1"... Quote
