drennich Posted December 18, 2017 Share Posted December 18, 2017 AutoCAD 2016 Right now we pdf (and it looks great), then we saveas a TIFF file. PDF lineweights look good, and so do the new TIFF lineweights. We are trying to publish straight to a TIFF file, but are lineweights are to fine. I've tried going into the imported "page setup" file and changing the lineweight in the page setup manager's "plot style table", but that did nothing. Any suggestions? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 19, 2017 Share Posted December 19, 2017 We publish to TIFF direct basicly had to redo the CTB table with thicker lines, as tiff's are controlled by the DPI so line thickness' tends to go thin. Quote Link to comment Share on other sites More sharing options...
drennich Posted December 19, 2017 Author Share Posted December 19, 2017 Thanks. This gave me some place to start. Got it to work in plot, but I'm still working on how to accomplish this when publishing. Doesn't seem to be taking the CTB from the imported file. Any hints? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 20, 2017 Share Posted December 20, 2017 I dont use publish rather a lisp and plot. You may need to set up the 1st sheet with correct parameters save its setting say as "TIFF" (plot screen top left) then in publish copy this setting to all sheets. Quote Link to comment Share on other sites More sharing options...
