AutoCAD 2018 with Fabrication MEP 2018 plot bug
Cerryl
My entire office is in the process of migrating to 2018 from 2016. We plot our drawings in color, however, all of the computers plot in greyscale for the viewport and color for paperspace where as before they plotted perfectly fine.
Found out that if I copy everything from one drawing and paste in a new drawing, it plots in color. We have hundreds of drawings, is there something saved to the dwg itself that would cause this? I have since saved the new drawing the same way as the old drawing, Autocad 2013, and when I re-open it, it plots color. Will attach snippets from each plot.
  • 3 weeks later...
Was using the correct CTB but there was a script that was loading that had errors in it's coding that I assume in 2016 didnt load because of those errors. Once we migrated to 2018 it was loading part of the script that was broken and changing settings.
