Wojciech Posted December 12, 2017 Posted December 12, 2017 (edited) Hi! I have problem with dimension leader, which is unfilled. Why? I have try FILLMODE, DIMTFILLCLR and DIMTFILL with no result. I think that this problem is related to rendering the view. Print is fine. Edited December 12, 2017 by Wojciech Quote
ReMark Posted December 12, 2017 Posted December 12, 2017 Are you referring to the tick marks (diagonal slashes)? Quote
Wojciech Posted December 12, 2017 Author Posted December 12, 2017 Yes Unfilled diagonal slashes. Quote
ReMark Posted December 13, 2017 Posted December 13, 2017 I wasn't aware that one could "render" using LT. When was that feature added? Did you try resetting all system variables to their default? Quote
steven-g Posted December 13, 2017 Posted December 13, 2017 Are you using shademode or hide? that will do it, and no way round it Quote
Dana W Posted December 13, 2017 Posted December 13, 2017 In your dimension style editor, have you inadvertently selected CLOSED BLANK for your arrowhead sub-style? That is probably not it but worth a look anyway. I tested it and cannot get any of my ARCHITECTURAL TICK arrowheads to go hollow like that. AutoCad LT does not render. It may be either a language translation issue, or the OP's software has not been updated on the forum. Quote
steven-g Posted December 14, 2017 Posted December 14, 2017 Shademode with the option hidden produces that result, it leaves arrows filled but for some reason hollows architectural ticks Quote
Yak Posted November 11, 2020 Posted November 11, 2020 Hi guys, Old topic, but for what it's worth: this "hollow architectural tick" appears when your drawing is not entirely flat. Even though you guys use LT, the elevation of points can appear. And then your dimensions will change from "filled" to "hollow". Make sure your drawing is flat (many ways: flatten (the worse, because rename you blocks); move to 0,0,1e99 and 0,0,-1e99; change properties elevation to 0). Purge the drawings and then do again some dimensions. That should work properly. Have fun 1 Quote
Dana W Posted November 12, 2020 Posted November 12, 2020 or you can hit a check into this box. 1 Quote
