Request: Lisp command that can quick swap text between two objects
I'm looking for a lisp command that can quick swap text between two objects, be they text, mtext, or multi-leader text. So upon running, you click on the two objects, and the text from object A moves to object B, and the text from object B moves to object A, where object A and object B can be different object types.
That's perfect, thank you! I legitimately have no idea how I missed that. :oops:
:lol: Heres one in "Tharwat's selecting" style:
(defun C:test ( / SS i o1 o2 s1 s2 )
 (cond
   ( (prompt "\nSelect two text objects to swap: ") )
   ( (not (setq SS (ssget "_:L-I"))) )
   ( (/= 2 (setq i (sslength SS))) (alert (strcat "Error: " (itoa i) " objects were selected.\n\nPlease Select EXACTLY two objects!")) )
     (not
       (vl-every
         '(lambda (a b c / x)
           (and
             (vlax-property-available-p (setq x (vlax-ename->vla-object (ssname SS a))) 'TextString)
             (set b x)
             (set c (vlax-get x 'TextString))
         '(0 1) '(o1 o2) '(s1 s2)
     (alert "\nOne or both of the objects doesn't support TextString property.")
   ( (mapcar 'vla-put-TextString (list o1 o2) (list s2 s1)) )
Won't work on nested objects tho.. :glare:
Hi,
I can't find my style in there. :danger::lol:
Why did not you add the DXF filter codes for text object along with the prompt message?
  Tharwat said:
Hi,
The first time I was introduced for a one-two-three-four object selection prompt with (ssget), was from one of your codes.
So with the time I started associating that technique with you, since usually most of us go for a (entsel) prompts.
Sometimes its more comfortable and faster for using. :)
Oh, you mean groupcode 1 ? I didn't thought of it!
I was about to use '(0 . "*TEXT*,*LEADER*,ATTDEF") but was lazy to write it (aswell think for all 0gcs that have TextString property).
Since I had to process the quite short-lengthed SS in order to obtain and reverse both string values, I didn't saw a reason to include (ssget) filters.
But I agree that with '(1 . "*") filter it would be better.
I will write it this way. :)
(defun c:txtswap (/ sel lst)
 (and (princ "\nSelect two text objects to swap: ")
      (setq sel (ssget "_:L" '((0 . "*TEXT"))))
      (or (= (sslength sel) 2)
          (alert "Must select two text objects only <!>")
      (setq lst (mapcar '(lambda (x) (vlax-ename->vla-object (ssname sel x))) '(0 1)))
      (mapcar 'vla-put-textstring (reverse lst) (mapcar 'vla-get-textstring lst))
) (vl-load-com)
  • Like 2
Looks alot simplier, :thumbsup:
BTW you could condense 1 row and skip two variables:
(mapcar 'vla-put-textstring lst (mapcar 'vla-get-textstring (reverse lst)))
Thanks
You were 13 minutes late. ;)
Ah, I didn't refresh the page before replying - sorry!
No worries at all and hope the OP finds these posts interesting.
  • 3 years later...
) (vl-load-com)
Expand
Sir how we will swap text/mtext/attribute text at one time if I have
More than 2 text object left side and right side
Ex:
Left       Right
1            5
A            f
3            ty
4.           150
Result after copy/swap/replace
Left
5
 f
 ty
150
Note: I will select all left side text at time, not one by one.
Then right side text all at one time select.
Hope you understand sir.
  • Dislike 1
What do you mean "copy/swap/replace"?
This I think was answered by PBE at Autodesk\forums or at least a method of picking text in a window  and making a list of it.
Mean sir, whatever is easy for program, copy , swap, replace, send that one.
Sir please send that link. Thanks
What I don't understand is, what happens to the text on the right after the command ends?
Better to make choice option sir
After command must ask choice , copy/swap/replace:
I will go with choice whatever I want for work.
Thanks
  • Dislike 1
Thanks
No worries. Would you by any chance be interested in learning the language? It will definitely save you hassles to keep requesting for code if nobody else is keen to help out. After all, you already know how to execute AutoLISP routines.
If you can attempt to write something up, post it here and see where you get stuck, we can assist you. Then the next time you want to code something up, you can actually do it yourself as opposed to posting in this forum. (Just my encouragement for you to take the first step to learning AutoLISP.)
Edited by Jonathan Handojo
  • Thanks 1
