mjavy7 Posted December 6, 2017 Share Posted December 6, 2017 Hello All! I would like to add another command to the pop up sub-menu (see attached image) that come up when you place your courser over a leader. I would like ADD the option to remove a leader right in this sub-menu. Is this possible? Here is the command that I think I need to add to this menu. ^C^C_MLEADEREDIT _R If this possible how do I get it done? Thanks in advanced. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 7, 2017 Share Posted December 7, 2017 If you type CUI you get into the menu's you can add extra menu items into a menu use COPY & Paste (right click on menu item) then edit the copied item to your required command. I dont do things that way I have custom menus and throw away all the stuff I dont want. eg 1 menu = 3 menu's of commands 99% of the stuff I use very day. Quote Link to comment Share on other sites More sharing options...
mjavy7 Posted December 7, 2017 Author Share Posted December 7, 2017 I will try it this morning. Thanks Bigal. Quote Link to comment Share on other sites More sharing options...
mjavy7 Posted December 7, 2017 Author Share Posted December 7, 2017 Bigal, I need more help. I went to the CUI and can not find the menu that I think I need. I went to: "ACAD" --> "Shortcut Menus" --> "MLeader Object Menu" and there is nothing in there like the picture above (1st post). Am I in the correct place/menu? A better explanation will be highly appreciated. Thanks in advanced. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 8, 2017 Share Posted December 8, 2017 I knew you would come back, I really dont touch the Acad menu's but rather have custom ones so I would add what you want to a custom one. I just had a real quick look at it and it seemed possible as copy a command is an option in the CUI. I may have time over weekend to look further which menu was it ? Quote Link to comment Share on other sites More sharing options...
tombu Posted December 12, 2017 Share Posted December 12, 2017 Bigal, I need more help. I went to the CUI and can not find the menu that I think I need. I went to: "ACAD" --> "Shortcut Menus" --> "MLeader Object Menu" and there is nothing in there like the picture above (1st post). Am I in the correct place/menu? A better explanation will be highly appreciated. Thanks in advanced. The "Shortcut Menu → MLeader Object Menu" is the one available when you right-click after selecting a MLeader Object. You can add your command macro in there, but the one you have displayed above is displayed when hovering over a grip on a selected MLeader Object. Those menus cannot be modified in the CUI. Quote Link to comment Share on other sites More sharing options...
mjavy7 Posted January 2, 2018 Author Share Posted January 2, 2018 The "Shortcut Menu → MLeader Object Menu" is the one available when you right-click after selecting a MLeader Object.You can add your command macro in there, but the one you have displayed above is displayed when hovering over a grip on a selected MLeader Object. Those menus cannot be modified in the CUI. Thanks tombu, I added it to the right-click menu and I can live with that :-). Quote Link to comment Share on other sites More sharing options...
