con Posted December 6, 2017 Posted December 6, 2017 When I'm working with the Architecture command "Wall" I can never select the outer side of the wall as a reference point. See the red dot, I'ld like to use this to draw the next wall from... Quote
SLW210 Posted December 6, 2017 Posted December 6, 2017 Haven't you already posted this same question once? Double posting is not allowed. Are you using AutoCAD Architecture? Your profile shows Mechanical. Quote
con Posted December 6, 2017 Author Posted December 6, 2017 Hi, Ow I couldn't find the older thread so I assumed something went wrong with publishing. I'm now testing Architecture, but the above thread-question is preventing me from working efficiently. Quote
SLW210 Posted December 6, 2017 Posted December 6, 2017 I have moved your thread to the Architecture & ADT Forum, please ask your questions in the most relevant forum. Quote
