Make Polyline segment vertical or horizontal
Hello,
is it possible to select segment of Polyline and make it vertical or horizontal by moving desired vertex (left or right / top or bottom) ?
Not sure if this works in AutoCAD (see questions in code). It works fine in BricsCAD. The code for a vertical segment is missing but would be very similar. Please test PolySegHor.
(vl-load-com)
(defun c:PolySegHor ( / doc idx lst obj par ref)
 (setq doc (vla-get-activedocument (vlax-get-acad-object)))
 (vla-endundomark doc)
 (vla-startundomark doc)
 (if
   (and
     (setq lst (entsel "\nSelect polyline segment near point to change: "))
     (setq obj (vlax-ename->vla-object (car lst)))
     (= "AcDbPolyline" (vla-get-objectname obj)) ; Only for "LWPOLYLINE".
     (setq par
       (vlax-curve-getparamatpoint
         obj
         (vlax-curve-getclosestpointto obj (trans (osnap (cadr lst) "nea") 1 0))
     (if (> 0.5 (rem par 1.0))
         (setq idx (fix par))
         (setq ref (1+ idx))
         (setq idx (fix (1+ par)))
         (setq ref (1- idx))
     (vla-put-coordinate ; Cannot use vlax-put?
       obj
       idx
       (vlax-3d-point ; 3d point OK?
         (list
           (car (vlax-safearray->list (vlax-variant-value (vla-get-coordinate obj idx)))); Cannot use vlax-get?
           (cadr (vlax-safearray->list (vlax-variant-value (vla-get-coordinate obj ref))))
           0.0
Here's another with some pretty colors :)
(defun c:foo (/ _2d b e i l n o p p1 p2 pa x)
  (defun _2d (p) (and p (setq p (list (car p) (cadr p)))) p)
  ;;RJP - 11.30.2017
  (while
    (and (not b)
	 (setq e (entsel "\nPick near vertex: "))
	 (= "LWPOLYLINE" (cdr (assoc 0 (entget (car e)))))
	 (setq p (vlax-curve-getclosestpointto (car e) (trans (cadr e) 1 0)))
	 (setq pa (fix (+ 0.5 (vlax-curve-getparamatpoint (setq e (car e)) p))))
	 (setq p (_2d (vlax-curve-getpointatparam e pa)))
	 (or (setq p1 (_2d (vlax-curve-getpointatparam e (1+ pa)))) t)
	 (or (setq p2 (_2d (vlax-curve-getpointatparam e (1- pa)))) t)
	 (setq
	   l (vl-remove-if
	       '(lambda (x) (or (member nil x) (equal x p 1e-8) (equal x p1 1e-8) (equal x p2 1e-8)))
	       (list (list (car p) (cadr p1))
		     (list (car p) (cadr p2))
		     (list (car p1) (cadr p))
		     (list (car p2) (cadr p))
		     (list (car p1) (cadr p2))
		     (list (car p2) (cadr p1))
	 (setq n 0)
	 (setq o "1-Red/2-Yellow/3-Green/4-Cyan/5-Blue/6-Magenta/7-White")
     (progn (foreach x l (grdraw p x (setq n (1+ n))))
	    (setq i (vl-string-search (itoa (1+ (length l))) o))
	    (setq o (strcat (substr o 1 i) "EXIT"))
	    (setq i "1-Red")
	    (initget 0 (vl-string-translate "/" " " o))
	    (if	(= (setq i (cond ((getkword (strcat "\n[" o "]<" i ">: ")))
				 (i)
		   "EXIT"
	      (setq b t)
	      (progn (entmod (mapcar '(lambda (x)
					(if (equal (cons 10 (list (car p) (cadr p))) x 1e-8)
					  (cons 10 (nth (1- (fix (atof i))) l))
					  x
				     (entget e)
	    (redraw)
(vl-load-com)
Edited by ronjonp
*fixed formatting mess from forum upgrade 1e-
Cool stuff Ron! :o
Just a few remarks:
  • Use (redraw) in the end, to prevent a possible confusion when working with 2 adjacent vertices
  • Add Back or Exit option to the getkword, so the user won't be forced to exit with error if he decides to do so
  • I'd wrap the whole thing within a (while) loop - but thats a personal taste
Perfect, Ron :)
that is much more than I expected and could imagine (all in one solution).
Just small remark: It work perfectly for Vertex but not for end points.
Cool stuff Ron! :o
Just a few remarks:
Thanks for the feedback :) .. code updated above.
You could also use Parametric dimensioning. To make a segment horizontal add a vertical parametric dimension to the segment and then change its value to 0.0. To make a segment vertical add a horizontal parametric dimension and change its value to zero. You can delete the dimension after the edit.
Thank you Roy_043,
in AutoCAD with error: Automation Error. Incorrect number of elements in SafeArray
Here is a revised version of my code. Based on the information I have found here I believe it should also work in AutoCAD. The commands are PolySegHor and PolySegVer.
(vl-load-com)
(defun PolySegChange (typ / doc idx lst obj par ptIdx ptRef ref) ; Typ is "HOR" or"VER".
 (if
   (and
     (setq par
         obj
         (setq ref (1+ idx))
         (setq ref (1- idx))
     (setq ptIdx (vlax-safearray->list (vlax-variant-value (vla-get-coordinate obj idx))))
     (setq ptRef (vlax-safearray->list (vlax-variant-value (vla-get-coordinate obj ref))))
     (vla-put-coordinate
       obj
       idx
       (vlax-safearray-fill
         (vlax-make-safearray vlax-vbdouble '(0 . 1))
         (if (= "HOR" typ)
           (list (car ptIdx) (cadr ptRef))
           (list (car ptRef) (cadr ptIdx))
(defun c:PolySegHor ()
 (PolySegChange "HOR")
(defun c:PolySegVer ()
 (PolySegChange "VER")
Perfect, Ron :)
I updated the code to work with end points. Give it a try.
Thank you very much :o
I love comprehensive routines as it is now.
It works nice.
Thank you Roy_043 :)
I forgot to mention, it works nice also with endpoints.
Thank you as well.
Hi,
is it possible to modify it to be working also with POLYLINE, not only LWPOLYLINE pls.?
  • 5 years later...
 ;;RJP - 11.30.2017
 (while
   (and (not b)
 (setq
   l (vl-remove-if
       '(lambda (x) (or (member nil x) (equal x p 1e- (equal x p1 1e- (equal x p2 1e-))
 (setq n 0)
    (setq i "1-Red")
			 (i)
	   "EXIT"
      (setq b t)
				  x
			     (entget e)
    (redraw)
(vl-load-com)
Hi everyone! Sorry to return to revive this thread so many years later. I tried Ronjonp's script but it seems like some parenthesis are cut off on the forum. I tried fixing but I'm not experienced with AutoLisp so I couldn't get it in a working state. Do you still have an older working version of that code?
I've updated the code here.
