Ashishs Posted November 28, 2017 Posted November 28, 2017 Hi, I am not able to Copy Paste any of the objects in attached drawing. new block.dwgFetching info... Errors as follows- *Warning* Multiply owned object, handle "27" pasteblock Duplicate definition of block _ArchTick ignored. INTERNAL ERROR: !dbdxfout.cpp@874: eNotThatKindOfClass Tried dxfout command, gived fatal error Tried (entdel(handent "27")) , No success tried Purge, insert and wblock commands , no success Quote
ReMark Posted November 28, 2017 Posted November 28, 2017 Is this the error you are referring to? *Warning* Multiply owned object, handle "23" I see via Audit that you also have a bad linetype. $AUDIT_BAD_LTYPE7 What is the source of the block? Quote
Ashishs Posted November 28, 2017 Author Posted November 28, 2017 This is received from our Client. How can we get rid of this bad linetupe?? Not even able to use qselect tool, gives fatal error....any suggestions?? Quote
ReMark Posted November 28, 2017 Posted November 28, 2017 What program did your client use to create the block? Quote
Ashishs Posted November 29, 2017 Author Posted November 29, 2017 Not Sure....The package contains some revit files as well...Client might have exported from revit & then further modified in AutoCAD. Quote
ReMark Posted November 29, 2017 Posted November 29, 2017 Please do not double post. It just causes confusion and splits responses between threads making it difficult to follow the course of the conversation. Quote
Ashishs Posted November 29, 2017 Author Posted November 29, 2017 Sure, noted...Not able to reach client. Does anyone has answer to this...? Quote
ReMark Posted November 29, 2017 Posted November 29, 2017 I have been unsuccessful in multiple attempts. I suggest you either redraw the block yourself or make a more determined effort to reach the client. Quote
Ashishs Posted November 29, 2017 Author Posted November 29, 2017 What I send you is just an extract from the drawing, I have several such drawings. I have attached one full drawing in below link for you, if it helps- Download link https://we.tl/4n5XJHjOf4 Quote
ReMark Posted November 29, 2017 Posted November 29, 2017 Are you telling us that the problem exists in all the drawings you received from your client? If that is the case then it is doubly important you contact the client. Quote
SLW210 Posted November 29, 2017 Posted November 29, 2017 No one else has responded to this thread, because ReMark has already given you all of the information you need. The errors are caused by these poorly done drawings, if the methods already given by ReMark are not fixing them, not very much else can be done, the client will have to give you workable drawings. Quote
Ashishs Posted November 29, 2017 Author Posted November 29, 2017 I have contacted client, they have done solid model in revit and then exported in AutoCAd & later modified in AutoCAd. So source is revit. They can't do anything about it. Quote
ReMark Posted November 29, 2017 Posted November 29, 2017 Then it looks like you will be redrawing it. Quote
RobDraw Posted November 30, 2017 Posted November 30, 2017 Your profile says that you are one 2010. The Revit model was probably exported to 2013 format which obviously isn't going to work well with 2010. Quote
Ashishs Posted December 5, 2017 Author Posted December 5, 2017 I joined this forum in 2010, but I am using AutoCAD 2017 now. I still have this problem. Quote
ReMark Posted December 5, 2017 Posted December 5, 2017 Only your client can solve the problem but they apparently don't care. So, what are you going to do about it? Quote
