JamyB Posted November 23, 2017 Share Posted November 23, 2017 Hi all, This one is a first for me. Using AutoCAD 2016. After selecting a solid hatch, I can't click and drag to select anything else within the hatch boundary. I can only select an object by picking on a line. I've never had this issue or noticed it before. Not sure if it's setting of just a CAD thing. Thanks for the help Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted November 24, 2017 Share Posted November 24, 2017 In the Options under Selection, you can toggle Associative Hatch selection. But that's not the answer, I tried it. Odd, never noticed that before. Then again, I'm not sure why you would draw something inside a solid hatch. Quote Link to comment Share on other sites More sharing options...
JamyB Posted November 24, 2017 Author Share Posted November 24, 2017 I've also tried the associative option. We're working with a large site plan with some colors. So all the building, ground material are all solid hatches. its a pain to select any multiple objects. And the same issue happens with any hatch at a small scale, not just Solid. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 27, 2017 Share Posted November 27, 2017 Can you post a drawing with an example that shows what's going on? Quote Link to comment Share on other sites More sharing options...
JamyB Posted November 27, 2017 Author Share Posted November 27, 2017 Sure. I've attached just a basic drawing with some lines inside a solid hatch. Select the hatch first, then try to select the lines while staying inside the hatch boundaries. HATCH PROBLEM.dwg Quote Link to comment Share on other sites More sharing options...
