"revcloud" command in lisp is different than "revcloud" AT command line
I understand that the revcloud command relies on a system variable in conjunction with a drawing's current annotation scale to try and scale the arc length appropriately, but it's always wrong. I wrote a lisp to make it the arc length constant, but I'm running into an issue with (command "revcloud").
Command: (command "revcloud" )
revcloud
Minimum arc length: 2'-0" Maximum arc length: 6'-0" Style: Normal Type: Freehand
Specify start point or [Arc length/Object/Style] : *Cancel*
Command: REVCLOUD
Specify first point or [Arc length/Object/Rectangular/Polygonal/Freehand/Style/Modify] : *Cancel*
Why are the options different? And how can I get all the options from within lisp?
Here's my w.i.p. lisp:
(defun c:RC1 (/)
 (setq TAB (getvar "TILEMODE"))
 (cond
   ((= TAB 0)
     (command "revcloud" "a" ".25" ".25")
     (while (> (getvar 'CmdActive) 0) (command pause))
   ((= TAB 1)
     (command "revcloud" "a" "24" "24")
That is strange. Here is a way to get all the prompts via lisp:
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "_.revcloud ")
If you use dimscale or something to set these numbers, it could be a multiplier like so .. just food for thought.
(defun c:foo (/ _dimscale doc n)
 (setq doc (vla-get-activedocument (vlax-get-acad-object)))
 (defun _dimscale (n)
   (* n
      (cond ;;in viewport
     ((and (zerop (getvar 'tilemode)) (> (getvar 'cvport) 1)) (last (trans '(0 0 1.0) 3 2)))
     ;;in pspace or dimscale is 0
     ((or (= (getvar 'cvport) 1) (zerop (getvar 'dimscale))) 1.)
     ;;in modelspace
     ((getvar 'dimscale))
 (setq n (vl-princ-to-string (_dimscale 0.25)))
 (vla-sendcommand doc (strcat "_.revcloud a " n " " n " "))
(vl-load-com)
Thanks ronjonp! I've never come across this before, but assume it has something to do with the recent (2016 or so) update autocad did with the revcloud command. Thanks for your workaround and suggestion using dimscale!
:beer: I didn't even realize that was a thing. Thanks for the knowledge!
Glad to help :)
  • 5 years later...
On 11/18/2017 at 12:03 AM, Grrr said:
Try using initcommandversion.
Bonjour,
initcommandversion 2 permet d'utiliser (command "_revcloud" pt1 pt2) dans Editeur Visual Lisp
Quand j'exécute fichier windows .BAT avec accoreconsole (Autocad 2023) et fichier .scr; j'obtiens: NIL erreur: no function  definition:nil
Why in visual lisp it work? Not working from .scr file?
WORKING: My visual lisp code:
Not Working .SCR
Edited by gricatti
