Jman Posted November 17, 2017 Share Posted November 17, 2017 (edited) I've been toying with this feature for a while and I must say it has saved me a lot of time. I have posted one of my dynamic casework blocks below. It is actually 4 individual pieces of casework in one block. Reason being is i have Handicap Accessible heights to deal with. Adult counter top height is 34"max. Elementary 29" max. and kindergarten/preschool is 24" max. Plus standard adult height which is 36" max. My problem here was the shelving arrangement. Because my casework is not all even dimensions, I couldn't use the stretch command and get even spacing. So i created one piece of casework and then set up 3 other visibility states. With each state I hid the previous cabinet and inserted another cabinet and so on. I also had to make a visual state for back splashes as on a wet wall or one that has a sink, i needed to have them. on others, i was able to turn them off I also had to do this for some dimensions as I also arrayed the casework and sometimes i don't need the overall dim to be there if only one cabinet is used. I'm sure there may be faster ways to do this but this one worked for me and I was able to eliminate single blocks out of my library making more space on the network drive. Anyway, I hope you like it. 180 - 36x24.dwg Edited November 17, 2017 by Jman grammer Quote Link to comment Share on other sites More sharing options...
