Hello all. First off let me thank Lee Mac for all that he does with LISP and how he helps others out. He is a great value to the community. :notworthy:
Now for the question I have been trying to get his Tip of the day lisp working. I have the lisp in my startup suite, it and the text file are both in a support file search path, and it does not show a tip at the start of the day. The Lisp does load because I can type (LM:tip) and it shows a tip, it just does not show anything for the first dwg of the day. Could the issue be that I am using Civil 3D 2015, maybe so variable that is causing the problem?
http://www.lee-mac.com/tipoftheday.html
Hi there. Just Shooting in the dark here.
The function is defined, so the problems seems to be with the s::startup definition. This is where it is handled.
(if (= 'list (type s::startup))
   (if (not (member '(LM:tip) s::startup))
       (setq s::startup (append s::startup '((LM:tip))))
   (defun-q s::startup nil (LM:tip))
My guess: Maybe another function loaded after LM tip of the day redefine s::startup before it is executed? To see if that is the case, try typing (defun-q-list-ref 's::startup), which will show you the list which is bound to s::startup. It should return "(nil (LM:TIP))" or a longer list which contain (LM:TIP) at the end of it. If not, then something redefine s::startup after LM:tip does its magic.
@Lee. If s::startup is not a list, s::Startup is defuned-q with (LM:tip). When I look at at AKN example for s::startup, they use defun (type = SUBR). With your code as is, if anyone has a s::startup defined using defun, from the test I made the part of LM:tip that I posted will overwrite it.
  Quote
Command: (defun s::startup () (princ"ya"))
S::STARTUP
Command: (s::startup)
ya"ya"
Command: (if (= 'list (type s::startup))
(_> (if (not (member '(LM:tip) s::startup))
((_> (setq s::startup (append s::startup '((LM:tip))))
((_> )
(_> (defun-q s::startup nil (LM:tip)))
S::STARTUP
Command: (defun-q-list-ref 's::startup)
(nil (LM:TIP))
I think a (= (type s::startup) 'SUBR) is needed, but if that is the case, is a workaround to "append" to a s::startup made using Defun?
Cheers!
For as long as I can remember, the formal documentation always advised to define the s::startup function as a list (i.e. using defun-q / defun-q-list-set), for example, as shown in this contradictory documentation from Autodesk.
Therefore, with this in mind, I would argue that if the s::startup function is not of list data type, it should be correctly redefined as such.
Thank you for your kind words aawilds, I appreciate your gratitude for my contributions to the community.
To test Jef!'s hypothesis above, you could try replacing lines 210-215 (inclusive) in the code with:
(LM:tip)
  Quote
I would not argue against defun-q being the best approach, as it enable the use of defun-q-list-ref, enables appending and/or setq differently.
I might argue that if someone has a 3rd party app that use defun, or chose to use defun, it is his choice. For all I know it is just because that someone stumbled on a contradictory Adesk piece of documentation. Even if I don't approve, and also think that it should be correctly redefined as such, I would still not skip subr verification and just overwrite it.
As always, I really appreciate the feedback you give.
Cheers! :)
(LM:tip)
That seems to be the issue it does now popup the tip on startup. The thing is I went through every other lisp that I have loaded with the startup suite and none of them change the s::startup function. It also opens a blank drawing I thought it would wait till the user picked a drawing to open. Thank you both with the help.
To see if it is defined, you can type !s::startup, with what has been said here it should returned something like #
Other that by the startup suite, It could be defined in a menu, a vlx, in acad.lsp or acaddoc.lsp, vba or in any other source that is loaded by any of the above in the first place. You could search for s::startup (in windows explorer) but if it is defined in an encrypted file, you wont find it. Happy hunting!
I'm glad I could help!
Have a nice week end!
I'm glad to hear that the program is now working well for you; if you wanted the tip to only be displayed for a saved drawing, you could test the DWGTITLED system variable prior to evaluating the (LM:tip) function when the program is loaded.
