chubarka Posted November 6, 2017 Posted November 6, 2017 Someone here please share with me the command sequence needed to put a .125" radius, between the end points of two lines using the arc tool. Thanking you is, Chubarka Quote
ReMark Posted November 6, 2017 Posted November 6, 2017 Fillet using the Radius option will work even if the lines do not meet. Quote
chubarka Posted November 6, 2017 Author Posted November 6, 2017 It seems that I did not explain myself properly, see attachment for how I need to use the arc tool in AutoCAD. Quote
chubarka Posted November 7, 2017 Author Posted November 7, 2017 I need to add the .125" radius at top bridged between the ends of the two vertical lines Quote
BIGAL Posted November 7, 2017 Posted November 7, 2017 I just did arc Enter for start, End, Radius value. It matched image. Quote
eldon Posted November 7, 2017 Posted November 7, 2017 (edited) When you use the Arc command, AutoCAD is consistent in trying to draw the arc anti-clockwise. So, in your case, start the arc from the left hand point and the arc will be as you want. If you start at the right hand end, the arc will be the wrong way round. However, instead of erasing it, you could always mirror it, or rotate it, or something else! Edited November 7, 2017 by eldon more thoughts Quote
f700es Posted November 7, 2017 Posted November 7, 2017 So at the apex (point) draw a circle at your specific radius and trim away items not needed? Any I missing something? Use the join command after if you need a closed pline. Quote
