lucky9 Posted November 4, 2017 Posted November 4, 2017 Hi, I'm new to this forum and Autocad lisp, I find the following code from about 7 year old (2010) thread. I started new thread as I don't know if bumping old thread is welcomed or not, most of the times bumping old threads are fawned upon on most forums. Now, lets get to the point, Source Code: Thread 21st Apr 2010 02:15 pm (defun c:PLab (/ obj) ;; Label each LWPolyline segment with number and distance ;; Alan J. Thompson, 04.21.10 (if (and (setq obj (car (entsel "\nSelect LWPolyline: "))) (or (eq "LWPOLYLINE" (cdr (assoc 0 (entget obj)))) (alert "Invalid object!") ) (setq obj (vlax-ename->vla-object obj)) ) ((lambda (n l / a b) (while (nth (1+ (setq n (1+ n))) l) (progn (vla-put-rotation (AT:MText (vlax-3d-point (vlax-curve-GetClosestPointTo obj (mapcar (function (lambda (x y) (/ (+ x y) 2.))) (setq a (nth n l)) (setq b (nth (1+ n) l)) ) ) ) (strcat (itoa (1+ n)) " - " (rtos (abs (- (vlax-curve-getDistAtPoint obj a) (vlax-curve-getDistAtPoint obj b) ) ) ) ) 0. nil 8 ) (angle a b) ) ) ) ) -1 (AT:ListGroupByNumber (vlax-get obj 'Coordinates) 2) ) ) (princ) ) ;;; Add MText to drawing ;;; Pt - MText insertion point ;;; Str - String to place in created MText object ;;; Wd - Width of MText object (if nil, will be 0 width) ;;; Lay - Layer to place Mtext object on (nil for current) ;;; Jus - Justification # for Mtext object ;;; 1 or nil= TopLeft ;;; 2= TopCenter ;;; 3= TopRight ;;; 4= MiddleLeft ;;; 5= MiddleCenter ;;; 6= MiddleRight ;;; 7= BottomLeft ;;; 8= BottomCenter ;;; 9= BottomRight ;;; Alan J. Thompson, 05.23.09 / 04.09.10 (defun AT:MText (Pt Str Wd Lay Jus / Wd s o) (or Wd (setq Wd 0.)) (setq s (if (or (eq acmodelspace (vla-get-activespace (cond (*AcadDoc*) ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) ) ) ) (eq :vlax-true (vla-get-mspace *AcadDoc*)) ) (vla-get-modelspace *AcadDoc*) (vla-get-paperspace *AcadDoc*) ) Pt (cond ((vl-consp Pt) (vlax-3d-point Pt)) ((eq (type Pt) 'variant) Pt) ) ) (setq o (vla-addMText s Pt Wd (vl-princ-to-string Str))) (and Lay (tblsearch "layer" Lay) (vla-put-layer o Lay)) (cond ((vl-position Jus '(1 2 3 4 5 6 7 8 9)) (vla-put-AttachmentPoint o Jus) (vla-put-InsertionPoint o Pt) ) ) o ) ;;; Group items in list based on specified number ;;; L - List to process ;;; # - Number of items for grouping ;;; Alan J. Thompson, 03.26.10 (defun AT:ListGroupByNumber (L # / n g f) (setq n -1) (while (> (1- (length L)) n) (repeat # (setq g (cons (nth (setq n (1+ n)) L) g))) (setq f (cons (reverse g) f) g nil ) ;_ setq ) ;_ while (reverse f) ) ;_ defun This above code is pretty good of what it does and what I was looking for. But here is a twist. It's placing text upside down in the following scenario: please have a look at the image attached here.. If anyone can please fix the lip would be highly appreciated. Thanks:) Quote
ronjonp Posted November 6, 2017 Posted November 6, 2017 Try this .. I included Alan's 'at:makereadable' function. (defun c:plab (/ obj) ;; Label each LWPolyline segment with number and distance ;; Alan J. Thompson, 04.21.10 (if (and (setq obj (car (entsel "\nSelect LWPolyline: "))) (or (eq "LWPOLYLINE" (cdr (assoc 0 (entget obj)))) (alert "Invalid object!")) (setq obj (vlax-ename->vla-object obj)) ) ((lambda (n l / a b) (while (nth (1+ (setq n (1+ n))) l) (progn (vla-put-rotation (at:mtext (vlax-3d-point (vlax-curve-getclosestpointto obj (mapcar (function (lambda (x y) (/ (+ x y) 2.))) (setq a (nth n l)) (setq b (nth (1+ n) l)) ) ) ) (strcat (itoa (1+ n)) " - " (rtos (abs (- (vlax-curve-getdistatpoint obj a) (vlax-curve-getdistatpoint obj b))) ) ) 0. nil 8 ) (at:makereadable (angle a b)) ) ) ) ) -1 (at:listgroupbynumber (vlax-get obj 'coordinates) 2) ) ) (princ) ) ;;; Add MText to drawing ;;; Pt - MText insertion point ;;; Str - String to place in created MText object ;;; Wd - Width of MText object (if nil, will be 0 width) ;;; Lay - Layer to place Mtext object on (nil for current) ;;; Jus - Justification # for Mtext object ;;; 1 or nil= TopLeft ;;; 2= TopCenter ;;; 3= TopRight ;;; 4= MiddleLeft ;;; 5= MiddleCenter ;;; 6= MiddleRight ;;; 7= BottomLeft ;;; 8= BottomCenter ;;; 9= BottomRight ;;; Alan J. Thompson, 05.23.09 / 04.09.10 (defun at:mtext (pt str wd lay jus / wd s o) (or wd (setq wd 0.)) (setq s (if (or (eq acmodelspace (vla-get-activespace (cond (*acaddoc*) ((setq *acaddoc* (vla-get-activedocument (vlax-get-acad-object)))) ) ) ) (eq :vlax-true (vla-get-mspace *acaddoc*)) ) (vla-get-modelspace *acaddoc*) (vla-get-paperspace *acaddoc*) ) pt (cond ((vl-consp pt) (vlax-3d-point pt)) ((eq (type pt) 'variant) pt) ) ) (setq o (vla-addmtext s pt wd (vl-princ-to-string str))) (and lay (tblsearch "layer" lay) (vla-put-layer o lay)) (cond ((vl-position jus '(1 2 3 4 5 6 7 8 9)) (vla-put-attachmentpoint o jus) (vla-put-insertionpoint o pt) ) ) o ) ;;; Group items in list based on specified number ;;; L - List to process ;;; # - Number of items for grouping ;;; Alan J. Thompson, 03.26.10 (defun at:listgroupbynumber (l # / n g f) (setq n -1) (while (> (1- (length l)) n) (repeat # (setq g (cons (nth (setq n (1+ n)) l) g))) (setq f (cons (reverse g) f) g nil ) ;_ setq ) ;_ while (reverse f) ) ;_ defun (defun at:makereadable (ang) ;; Make angle readable ;; Alan J. Thompson, 12.14.10 (if (and (> ang (/ pi 2.)) (<= ang (* pi 1.5))) (+ ang pi) ang ) ) Quote
NADER-2020 Posted November 5, 2020 Posted November 5, 2020 HI , this is good lisp , but it working for one object . i want to use it for multi object Quote
BIGAL Posted November 5, 2020 Posted November 5, 2020 Do you know anything about lisp in particular using ssget then the repeat function, these would replace the entsel method which is one at a time near the top of the code. So a few lines at top and 1 near end to close the repeat function. Quote
NADER-2020 Posted November 7, 2020 Posted November 7, 2020 i am asking for help because i am not good in lisp, so if u can help me i would grateful to you . Quote
lucky9 Posted November 8, 2020 Author Posted November 8, 2020 Im good at vba but i find it difficult to learn lisp programming, i wonder if there is free easy learning tutorial source available whcih covers a to z about autolisp programming would be wonderful. Quote
BIGAL Posted November 8, 2020 Posted November 8, 2020 Here is multiple selection added it is not labelling the last segment not sure why will try to find time to look at it. I know Alan JT is on some forums he may have updated the code. ;; Label each LWPolyline segment with number and distance ;; Alan J. Thompson, 04.21.10 (defun c:plab (/ obj k ) (if (= (setq ss (ssget (list (cons 0 "LWPolyline")))) nil) (progn (alert "Invalid objects picked exiting now !")(exit)) (repeat (setq K (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq k (- k 1))))) ((lambda (n l / a b) (while (nth (1+ (setq n (1+ n))) l) (progn (vla-put-rotation (at:mtext (vlax-3d-point (vlax-curve-getclosestpointto obj (mapcar (function (lambda (x y) (/ (+ x y) 2.))) (setq a (nth n l)) (setq b (nth (1+ n) l)) ) ) ) (strcat (itoa (1+ n)) " - " (rtos (abs (- (vlax-curve-getdistatpoint obj a) (vlax-curve-getdistatpoint obj b))) ) ) 0. nil 8 ) (at:makereadable (angle a b)) ) ) ) ) -1 (at:listgroupbynumber (vlax-get obj 'coordinates) 2) ) ) ) (princ) ) ;;; Add MText to drawing ;;; Pt - MText insertion point ;;; Str - String to place in created MText object ;;; Wd - Width of MText object (if nil, will be 0 width) ;;; Lay - Layer to place Mtext object on (nil for current) ;;; Jus - Justification # for Mtext object ;;; 1 or nil= TopLeft ;;; 2= TopCenter ;;; 3= TopRight ;;; 4= MiddleLeft ;;; 5= MiddleCenter ;;; 6= MiddleRight ;;; 7= BottomLeft ;;; 8= BottomCenter ;;; 9= BottomRight ;;; Alan J. Thompson, 05.23.09 / 04.09.10 (defun at:mtext (pt str wd lay jus / wd s o) (or wd (setq wd 0.)) (setq s (if (or (eq acmodelspace (vla-get-activespace (cond (*acaddoc*) ((setq *acaddoc* (vla-get-activedocument (vlax-get-acad-object)))) ) ) ) (eq :vlax-true (vla-get-mspace *acaddoc*)) ) (vla-get-modelspace *acaddoc*) (vla-get-paperspace *acaddoc*) ) pt (cond ((vl-consp pt) (vlax-3d-point pt)) ((eq (type pt) 'variant) pt) ) ) (setq o (vla-addmtext s pt wd (vl-princ-to-string str))) (and lay (tblsearch "layer" lay) (vla-put-layer o lay)) (cond ((vl-position jus '(1 2 3 4 5 6 7 8 9)) (vla-put-attachmentpoint o jus) (vla-put-insertionpoint o pt) ) ) o ) ;;; Group items in list based on specified number ;;; L - List to process ;;; # - Number of items for grouping ;;; Alan J. Thompson, 03.26.10 (defun at:listgroupbynumber (l # / n g f) (setq n -1) (while (> (1- (length l)) n) (repeat # (setq g (cons (nth (setq n (1+ n)) l) g))) (setq f (cons (reverse g) f) g nil ) ;_ setq ) ;_ while (reverse f) ) ;_ defun ;; Make angle readable ;; Alan J. Thompson, 12.14.10 (defun at:makereadable (ang) (if (and (> ang (/ pi 2.)) (<= ang (* pi 1.5))) (+ ang pi) ang ) ) Quote
