Hello,
I am trying to create a dimension style using VBA Excel. I have a simple code as follows:
Option Explicit
Sub New_Layer()
Dim acadApp As AcadApplication
Dim acadDoc As AcadDocument
Dim mSp As AcadModelSpace
Dim dimstyle As AcadDimStyle
Dim sDim As AcadDimAligned
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
Dim location(0 To 2) As Double
'Check if AutoCAD is open.
On Error Resume Next
Set acadApp = GetObject(, "AutoCAD.Application")
On Error GoTo 0
'If AutoCAD is not opened create a new instance and make it visible.
If acadApp Is Nothing Then
Set acadApp = New AcadApplication
acadApp.Visible = True
End If
'Check if there is an active drawing.
Set acadDoc = acadApp.ActiveDocument
On Error GoTo 0
'No active drawing found. Create a new one.
If acadDoc Is Nothing Then
Set acadDoc = acadApp.Documents.Add
End If
Set mSp = acadDoc.ModelSpace
'Dimension points
point1(0) = 0#: point1(1) = 5#: point1(2) = 0#
point2(0) = 6.1: point2(1) = 5: point2(2) = 0#
location(0) = 5#: location(1) = 4.4: location(2) = 0#
'Add dimension
Set sDim = acadDoc.ModelSpace.AddDimAligned(point1, point2, location)
'Set dimension properties
sDim.Color = acByLayer
sDim.ExtensionLineExtend = 0
sDim.Arrowhead1Type = acArrowOblique
sDim.Arrowhead2Type = acArrowOblique
sDim.ArrowheadSize = 0.1
sDim.TextColor = acGreen
sDim.TextHeight = 0.2
sDim.UnitsFormat = acDimLDecimal
sDim.PrimaryUnitsPrecision = acDimPrecisionOne
sDim.TextGap = 0.1
sDim.LinearScaleFactor = 100
sDim.ExtensionLineOffset = 0.1
sDim.VerticalTextPosition = acOutside
'Create a new dimension style
Set dimstyle = acadDoc.DimStyles.Add("D100")
'Copy dimension properties from previously added dimension
dimstyle.CopyFrom (sDim)
'Delete dimension
sDim.Delete
End Sub
However
line does not working. I am getting following error: "Object doesn't support this propert or method"
I couldn't find what I am doing wrong. I am using AutoCAD 2013 and Excel 2016.
Thank you!
using dimstyle.CopyFrom sDim instead of dimstyle.CopyFrom (sDim) solved my problem. that was easy. sorry for posting this.
Interesting code - it shows the fully activex approach to create dimension style.
I was familiar only with pre-setting certain system variables + command calls, before creating the new dim style.
So that approach was going to be replicated into your code: (vla-SetVariable acaddoc ...) would be used.
Interesting to look at lisp v's VBA for same task when googled, Grr Setvariable is a supported method in VBA.
Remember seeing a entmake with every variable described somewhere.
