Help lisp autonumber Attribute
Hi, everybody.
Please help me lisp Select polyline and autonumber Attribute with circle 7.5.
Thank you very much.
File attach:
G ATT.dwg
There are lots of get the vertices of a pline routine here is one. It makes a list of all the points in order just add the circle and text option.
Did you search for "Number Pline vertices" should exist would then be easy to add the circle bit.
; pline co-ords example
; By Alan H
(defun getcoords (ent)
 (vlax-safearray->list
   (vlax-variant-value
     (vlax-get-property
   (vlax-ename->vla-object ent)
   "Coordinates"
(defun co-ords2xy ()
; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z
(setq len (length co-ords))
(setq numb (/ len 2)) ; even and odd check required
(setq I 0)
(repeat numb
(setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) ))
; odd (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) ))
(setq co-ordsxy (cons xy co-ordsxy))
(setq I (+ I 2))
; program starts here
(setq co-ords (getcoords (car (entsel "\nplease pick pline"))))
(co-ords2xy) ; list of 2d points making pline
(princ co-ordsxy)
add this bit for circle I will let you work out text
(repeat (setq x (length co-ordsxy))
(command "circle" (nth (setq x (- x 1)) co-ordsxy) 7.5)
; By Alan H
   (vlax-variant-value
     (vlax-get-property
   "Coordinates"
(setq I 0)
(repeat numb
(setq I (+ I 2))
(princ co-ordsxy)
; By Alan H
   (vlax-variant-value
     (vlax-get-property
   "Coordinates"
(setq I 0)
(repeat numb
(setq I (+ I 2))
(princ co-ordsxy)
I edited the same.
Thanks BIGAL.
Result image attach:
