.layout file type
Has anyone ever converted a .layout file type to AutoCAD? I was sent drawings with that file type but I can't do anything with them. How do I convert them to dwg?
Right now all I have is AutoCAD 2006 and I can't seem to figure out how to do anything with that. I don't really want to go through the trouble of downloading the free trial of AutoCAD unless I know for sure that it will be a fairly smooth conversion.
Thanks!
.layout is a filetype created by Sketchup LayOut.
https://help.sketchup.com/ru/article/3000194
There is a plugin that allows you to open Sketchup files in newer Acad versions - but I'm not sure if you can use it with 2006, and I'm not sure if it only imports .SKP files.
https://apps.autodesk.com/ACD/en/Detail/Index?id=4545979311403124726&appLang=en&os=Win32_64
You may need to ask whoever sent you the file to send it again in .dwg or .dxf format.
Sketchup Pro can produce either of these.
https://help.sketchup.com/sv/article/3000235
https://help.sketchup.com/sv/article/3000153
I will just ask him to convert it for me I guess.
Thanks for the info!
