(c:DrawMe) finally updated in order to remove reported bugs... To fix this issue I considered that Dang1 variable must be whole number multiplication of main unit angle Dang0 ( or eventually 1/whole number )... So to fix this I've added one more edit_box variable into DCL called angfact - it must be whole number or 1/whole number... Default value is 2 to mimic original authors curve, and now no need for :
(while (or (= (length path) 1) (not (< (distance (car path) (last path)) (distance (last path) (cadr (reverse path)))))) ... )
It is only needed this :
(while (or (= (length path) 1) (not (equal (car path) (last path) 1e-6))) ... )
So I am finished with this I hope for everyone's happiness...
Regards, yours M.R., d.i.a. (arch.)
  • 2 years later...
I just find out that Inventor has a module for dynamic simulation. I built a simple mechanism and I started to learn by playing. I’ve got the some images like the ones I posted here before, showing the trace of the pen on the central disc. No Lisp or programming of any kind! I wish I knew this two years ago.
However, I remember it was a pleasure to write those Lisp programs. Also I enjoyed discussing about it here in the forum.
So, to make the short story even shorter: see here some screen captures.
sim03.png.04667dfd21d692fd9a64d5f961eaac3a.pngsim02.png.328bca527ddf17848578fcc3a1ac576a.pngsim01.png.eac3b3aa61eaa1294eec2ca398b9ad53.png
  • Like 2
Fuccaro said "I will make such a drawing machine for my children". Google spirograph its a toy. Can spend hours on it.
For the dcl have a look in downloads Multi getvals and Multi Radio buttons library defuns can be used in any code dynamic input only 2 lines of code to run.
What a nice program that google Spirograph! Probable I will either spend some hours on it. Thanks for that!
I made that machine, my girls already destroyed it after a few months. And about the DCL: I never wrote a single line of DCL file. Maybe this time I will give it a try…
Best wishes to all of you!
fuccaro the multi programs mean you do not write any dcl code it does it for you 1 line input, or  2, 3 to around 20+ its screen dependant for maximum, it returns a list of variables entered, you can set default values like wise you can make it remember last entry.
Edited by BIGAL
