Looked through threads and couldn't find any images of the HVAC elective project. If anyone has the project or can find images of the 4 plates could you please post it? Thanks in advance
This wouldn't be HVAC Project 9 would it?
If not, can you attach a copy of the PDF that describes the project?
Edited by ReMark
Yes ReMark this is the HVAC elective Project 9. I would just like an image of the plates just to make sure I'm on the right track. Its tough figuring out the ductwork without an image of what it should look like. I'm a visual learner
Does the image below match up with the project scope for plate 1?
That's it! Thanks for finding it for me!!
Is there anyway you could find the last 3 plates for this project? or direct me to a thread about this elective?
You do realize that part of this learning process is the ability to follow written instructions? You are not always going to get a drawing of the object(s) you are supposed to draw. It some cases you'll be lucky if you get a rough sketch.
The three remaining plates as per your request.
Plate 2
Plate 3
Plate 4
