How to get data to an attribute from enclosing polyline's property
Dear folks,
There is an idea to get things easier in my workflow but I need check if it is possible or not.
There are over 100 closed polyline objects on the model and each has a unique ID written in its Hyperlink value (like X_D_YYYY)
And each of these polylines has a block placed in the enclosing area with an attribute.
My aim is to get the Hyperlink from enclosing polyline and populate the block attribute with that value.
You may find an example as DWG at the attachment.
Regards.
get-Enclosing-polyline-data.dwgFetching info...
