Sengna Posted September 19, 2017 Share Posted September 19, 2017 It is very annoying that when i was working on model space, the file path of the previous drawing/Drive appears on the screen and block the object that i was working on, It is any annoying and i was wondering if anyone know how can i turn it off. Thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 19, 2017 Share Posted September 19, 2017 One suggestion I saw said to set STARTMODE to a value of 0. Quote Link to comment Share on other sites More sharing options...
Sengna Posted September 19, 2017 Author Share Posted September 19, 2017 One suggestion I saw said to set STARTMODE to a value of 0. awesome, i went in and checked and it was set at 1 so i used the command you suggested and set to 0, so far i haven't see the annoy file path show up yet. hope this will work. Thanks you so much Remark, you are a genius Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 19, 2017 Share Posted September 19, 2017 If I was that smart I wouldn't have had to go searching for the answer; I would have known it already. Thanks anyway. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 19, 2017 Share Posted September 19, 2017 Thanks remark I have lived with this problem for around 18 months since we got new pc's, happens sometimes could never work out the exact sequence that caused it, will give it a try. Quote Link to comment Share on other sites More sharing options...
