BIGAL Posted September 21, 2017 Posted September 21, 2017 There is a thing called hard clip limit even though you say plot a A1 594mm if the clip is set at 420 it will only plot to there but push a full size A1 sheet out. This referred to say in Word as the Margins. If you had preprinted sheets you could force only plotting in certain areas of the sheet. Lastly this is not set now in the PDF plotting only when you go direct else all would be wrong. Quote
Steve Johnstone Posted September 25, 2017 Author Posted September 25, 2017 So where do I find the settings for Hard clip limit to determine if that is the problem.. Quote
ReMark Posted September 25, 2017 Posted September 25, 2017 Please attach a copy of the drawing file you are experiencing the problem with so someone here can actually do a test plot. Thank you. BTW...who created the drawing? Was it done in-house or by an outside company? Quote
