Lisp to create a boundary around blocks that are not touching.
Dear All,
I used Ron's code and it works flawlessly on the test drawing that I made. Unfortunately, and it is my fault, I didn't really consider a few things that seems to be causing problems.
1) The blocks that we use are not just a simple block. I had to strip stuff out from inside of them due to protecting company private stuff. We have some geometry inside of those blocks which seems to be causing problems. What it does when we have our actual blocks being used is it freaks out and does something like this:
https://imgur.com/a/u3H7C
What is happening is it outlines every block and then does this strange bounding box like thing.
Could we maybe specify in the LISP to ONLY check certain layers and ignore everything else? I don't know much about LISP so if I am asking to move heaven and earth please tell me to go fly a kite. :)
2) The second issue I am seeing is when we have an opening inside of an array of blocks like in the example below. Ron's source code does an offset and then brings it back to the edges which is fantastic, but the issue is if we have a shorter block inside it will not offset the outer most line that was generated. I'm not sure if there is a way to intelligently tell it to ignore a gap like that. The line being drawn is really not an issue. I can always delete it. But is there a way to always offset that outer line back to the very edge?
https://imgur.com/a/JAAfp
I also want to take a moment to thank all of you again for your help. I know I am asking a lot. I appreciate it a lot! If any of you are going to Autodesk University let me know. I owe you a beer or 2!
  BIGAL said:
I did a lot of googling and there is a solution at Mathlab that gives a second order soultion a more closely defined shape joining points but it does have a cost.
Found a couple of others but again at cost. there was one site but had to join to get the code www.github.com
Cost is not really a concern for me as long as it is not outrageous and there is an ability to test it in some capacity before using it. Could you link to it? I am not sure if that breaks any rules of the site or not.
  BIGAL said:
Nice one guys but look at my image it closer to a true shape desired joining end points, as I said I spent around 2 hours researching this and there are algorithms out there the github was real close even coding in common LISP that would provide a starting point for Autolisp, then I lost the page and now can not find. I may join Github to find an answer. They work on random points not shapes. This is the similar approach to tracing images. There is a huge wealth of information on the theory but not actual code, some examples are there in c# etc. There is a 1st order solution then a more advanced 2nd order which is like what I have posted.
There appears to be two solutions a random 1 my image or a more ortho answer by Lee & Marko what does the poster want ?
Hey BIGAL,
I am not knowledgeable enough on the subject to have a reasonable opinion of one way over the other I will be honest. This thread has really made me look into learning LISP and AutoLISP though.
I am completely open to all approaches for this. This is seems like a great discussion on how to tackle my issue though. Hopefully people are getting a lot of good information from one another in here. I really appreciate all the help a ton. You guys are awesome!
  • 2 years later...
  On 9/18/2017 at 8:30 PM, ronjonp said:
Give this a try .. seemed to work OK on your example drawing.
(defun c:uunion	(/ _off b e off reg regions s s2 sp tmp x)
 ;; RJP 09.18.2017
 ;; UGLY effin code, but works on sample drawing .. can it be broken? But of course ;-)
 (defun _off (o d f / out tmp)
   (foreach di	(list d (- d))
     (if
(not (vl-catch-all-error-p (setq tmp (vl-catch-all-apply 'vlax-invoke (list o 'offset di))))
 (setq out (cons (car tmp) out))
   (cond ((= 2 (length out))
   (setq out (vl-sort out '(lambda (a b) (f (vla-get-area a) (vla-get-area b)))))
   (vla-delete (cadr out))
   (car out)
  (car out)
 (or (setq off (getdist "\nPick distance to check < 15 >: ")) (setq off 15))
 (if
   (and (setq sp (vlax-get (vla-get-activedocument (vlax-get-acad-object))
		    (if	(= (getvar 'cvport) 1)
		      'paperspace
		      'modelspace
 (setq s (ssget ":L" '((0 . "insert"))))
 (setq s (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))))
 (setq s (mapcar '(lambda (x) (car (vlax-invoke x 'explode))) s))
 (setq s2 (mapcar '(lambda (x) (car (_off x off >))) s))
 (setq regions (vlax-invoke sp 'addregion s2))
    (progn (mapcar 'vla-delete s)
    (mapcar 'vla-delete s2)
    (foreach reg regions
      (mapcar (function (lambda (x) (vl-catch-all-apply 'vla-boolean (list reg acunion x))))
	      (vl-remove reg regions)
    (setq b (vlax-ename->vla-object (setq e (entlast))))
    (entmod (subst '(8 . "RJP_Outline") (assoc 8 (entget e)) (entget e)))
    (vlax-invoke b 'explode)
    (if	(setq s (ssget "_x" '((0 . "line,arc,lwpolyline") (8 . "RJP_Outline"))))
      (if (= 1 (getvar 'peditaccept))
	(command "_.pedit" "Multiple" s "" "Join" 0.0 "")
	(command "_.pedit" "Multiple" s "" "y" "Join" 0.0 "")
    (vla-delete b)
    (setq b (vlax-ename->vla-object (entlast)))
    (_off b off <)
    (vla-delete b)
(vl-load-com)
Expand
Hi Ron,
Your lisp is just i was looking for as i guess.But it seems does not work on Autocad 2019 and Autocad Civil 3D 2019 Versions.I have a bunch of points to have boundary arround.When i run the lisp, it does not select any objects at all.Please check the attached video and dwg file.Thank you in advance.
umit
Autodesk Civil 3D 2019 - [Drawing1.dwg] 2020-03-06 17-46-05.rarFetching info... points.dwgFetching info...
It is supposed to be working with geometry like blocks (INSERT) with curve geometry, not with points like you showed in your video... I am afraid that there is no algorithm that would do what you want to achieve... You could try though to make TIN surface and remove convex triangles manually... Finally you should create regions from triangles that are making boundary you want to keep, and union them to remove common edges after which you should explode boundary region and join boundary into final polyline...
"convex triangles manually" known as remove long triangles very handy when grid type points are involved, CIV3D has delete a triangle it actually does not delete rather does not display.But then you can export triangles and try code. LineworkShrinkwrap should now work.
Hi,
I also have the code in the link below ( Example Program 1) which belongs to Lee Mac.It seems working  with points but it does not have a distance (cleareance) option that i certainly need.
http://www.lee-mac.com/convexhull.html
And also it does not work on my machine and gives the following error.
Command: test1
Select objects: Specify opposite corner: 1977 found
Select objects:
; error: no function definition: LM:CONVEXHULL
Command:
Thank you
Umit
Command: test1
Select objects:
Command:
Expand
You need to download & load the LM:ConvexHull function from the link at the top of the page.
Edited by Lee Mac
  • 10 months later...
 ;; RJP 09.18.2017
     (if
   (car out)
  (car out)
 (if
		      'paperspace
		      'modelspace
    (vla-delete b)
    (_off b off <)
    (vla-delete b)
(vl-load-com)
hi ronjop, i try use this code, but i can´t get that the progran catch the object, i try to do with rectangle in another time with blockhi ronjop, i tried use this code, but i can´t get that the program catch the object, i tried to to with rectangle in another time with block. can you help me?
Expand
  • 2 weeks later...
 ;; RJP 09.18.2017
     (if
   (car out)
  (car out)
 (if
		      'paperspace
		      'modelspace
    (vla-delete b)
    (_off b off <)
    (vla-delete b)
(vl-load-com)
Expand
am getting this error
Command: UUNION
Select objects: Specify opposite corner: 6 found
Select objects:
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
Like the recommendation above, try changing the two command calls to command-s.
Expand
so from
will become?
command-s "_.pedit" "Multiple" s "" "Join" 0.0
  On 2/1/2021 at 8:51 AM, CAD_Noob said:
so from
will become?
Expand
Like this:
  (command-s "_.pedit" "Multiple" s "" "Join" 0.0 "")
  (command-s "_.pedit" "Multiple" s "" "y" "Join" 0.0 "")
  On 2/1/2021 at 10:58 AM, ronjonp said:
Like this:
Expand
Thanks so much Ron...working fine now.
  • 8 months later...
  On 9/17/2017 at 10:24 AM, Lee Mac said:
I have the following, but there are still some bugs -
Expand
Lee, i couldn't found the code at lee-mac.com . Found only The outlineobjects command that works only with touching objects.
Can you post the code that works as the gif?
And thanks for your material at the site, I found a lot of good information about lisp coding there.
Best regards
Best regards
Expand
Never mind, just found it. Thanks!
Expand
I don't think I ever shared this code to the forums as I never got around to ironing out all of the bugs...
