Split Single line Mtext object into Two line Mtext based on / symbol
Hi Everyone
I have a lots of Mtext objects in my drawing file (as shown in below image),i want split into two lines (as shown in below image) and manual editing taken more time.
i want like this, if I click on the Mtext, the first digits (before /) comes in first line.then (/) should be removed, rest of the texts comes in second line, all text rotation should be zero (0), text height should be 2mm and style should be Aerial Black.
Before
After
Please help me anyone on this.
Please let me know is this possible?
Thanks in advance
Edited by gmmdinesh
Hi Everyone
Before
[ATTACH=CONFIG]62144[/ATTACH]
After
[ATTACH=CONFIG]62145[/ATTACH]
Thanks in advance
As start point..
(and (setq en (car (entsel)))
    (setq $ (vla-get-TextString (vlax-ename->vla-object en)))
    (vla-put-Textstring (vlax-ename->vla-object en) (vl-string-subst "\\P" "/" $))
;have a look at dump properties
(vlax-dump-object (vlax-ename->vla-object en))
vla-put-height
vla-put-StyleName
;etc..
keep trying yourself
Don't know formatting Mtext?
Suggestion:
manually edit in MTEXT editor ARIAL BLACK etc..
then select entity look at Properties dialog -> TEXT -> Contents it will show format something like:
"{\\fArial Black|b0|i0|c0|p34; ....... }"
Tips: strcat
maybe Unformat is useful before applying any changes my $0.02
Why did you post it again !
It was answered in other post did you try the code I did. All the answers are there.
Administrator please merge.
Really sorry.. actually the answer thread not shown for me on that day..
Hi hanhphuc
I will try your code and get back to you.
Thanks
