help! Masters; EXTRACT VERTEX X,Y choose first point at way clockwise (need upgrade)
leo321
I had this from Lee, but usually always go way counter-clockwise and only select the polyline, not the point.
;; Polyline Vertex Exporter ~ by Lee McDonnell ~ 26.11.2009
(defun c:pExp2 (/ ss tmp i j ent tot dis pt)
(vl-load-com)
(if (and (setq ss (ssget '((0 . "*POLYLINE"))))
(setq tmp (getfiled "Output File" (cond (*load) ("")) "txt;csv" 9)))
(setq *load tmp tmp (open tmp "a") i -1)
(write-line "X,Y,Layer" tmp)
(while (setq ent (ssname ss (setq i (1+ i))))
(setq tot 0. j (1- (vlax-curve-getStartParam ent)))
(while (
(setq pt (mapcar 'rtos (vlax-curve-getPointatParam ent j)))
(write-line
(strcat (car pt) (chr 44) (cadr pt) (chr 44) (vla-get-layer (vlax-ename->vla-object ent)))
tmp))
(write-line "" tmp))
(close tmp)))
(princ))
THX for any tips.
Wow, that's some old code...
I don't quite understand, what do you want the code to do?
PS: Please edit your post and enclose your code with code tags:
[highlight][noparse]
[/noparse][/highlight]Your code here[highlight][noparse]
I´ll try explian;
the file returns the polyline reverse clockwise way sample;
X,Y,Layer
485172.23,6691696.77,FC 0059
485157.93,6691697.48,FC 0059
485156.58,6691666.50,FC 0059
485171.15,6691665.78,FC 0059
I would like th clockwise side return, (above)
If can select the FIRST vertex it will be perfect;
take this oportunite to say I follow this years, your are the guy, congrates
sorry for my bad english
Edited by leo321
Thank you for your compliments :thumbsup:
Please try the following:
(defun c:ptx ( / *error* des ent enx lay lst txt )
   (defun *error* ( msg )
       (if (= 'file (type des)) (close des))
       (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
   (if (setq txt (getfiled "Create Output File" (cond ( ptx:dir ) ( "" )) "txt;csv" 1))
       (while
           (not
               (progn (setvar 'errno 0) (setq ent (car (entsel "\nSelect 2D polyline <Done>: ")))
                   (cond
                       (   (= 7 (getvar 'errno))
                           (prompt "\nMissed, try again.")
                       (   (null ent))
                       (   (/= "LWPOLYLINE" (cdr (assoc 0 (setq enx (entget ent)))))
                           (prompt "\nThe selected object is not a 2D polyline.")
                       (   (not
                               (or des
                                   (and (setq des (open txt "w"))
                                        (setq ptx:dir (strcat (vl-filename-directory txt) "\\"))
                                        (write-line "X,Y,Layer" des)
                           (princ (strcat "\nUnable to open \"" txt "\" for writing."))
                       (   (setq lst (mapcar 'cdr (vl-remove-if-not '(lambda ( x ) (= 10 (car x))) enx))
                                 lay (list "," (strcat "," (cdr (assoc 8 enx))))
                           (foreach vtx (if (LM:listclockwise-p lst) lst (reverse lst))
                               (write-line (apply 'strcat (mapcar 'strcat (mapcar 'rtos vtx) lay)) des)
                           (write-line "" des)
                           (prompt (strcat "\n" (itoa (length lst)) " vertices written to " (vl-filename-base txt) (vl-filename-extension txt) "."))
       (princ "\n*Cancel*")
   (*error* nil) (princ)
;; List Clockwise-p - Lee Mac
;; Returns T if the point list is clockwise oriented
(defun LM:listclockwise-p ( lst )
   (minusp
       (apply '+
           (mapcar
               (function
                   (lambda ( a b )
                       (- (* (car b) (cadr a)) (* (car a) (cadr b)))
               lst (cons (last lst) lst)
And another, allowing optional selection of a start point:
(defun c:ptx ( / *error* cnt des dis ent enx idx lay lst spt tmp txt )
       (while
           (not
                   (cond
                       (   (null ent))
                       (   (not
                               (or des
                                 lst (if (LM:listclockwise-p lst) lst (reverse lst))
                           (if (setq spt (getpoint "\nSpecify start point <use first vertex>: "))
                                   (setq idx 0
                                         cnt 1
                                         spt (trans spt 1 ent)
                                         dis (distance spt (car lst))
                                   (foreach pnt (cdr lst)
                                       (if (< (setq tmp (distance spt pnt)) dis)
                                           (setq dis tmp
                                                 idx cnt
                                       (setq cnt (1+ cnt))
                                   (repeat idx (setq lst (append (cdr lst) (list (car lst)))))
                           (foreach vtx lst
                           (write-line "" des)
   (minusp
       (apply '+
           (mapcar
               (function
                   (lambda ( a b )
Thanks a lot, when come to Brazil your beer is guarantees, it´ll be a honor.
