Filename in Field Form
CAD_Noob
Hi again, I need help.
I want the user to pick a TEXT, MTEXT or Attribute and the lisp will input the Filename of the drawing in Field form as value (without the filename extension .dwg)
Can it be done?
Yes - use Visual LISP to populate the Text, MText or Attribute content with the appropriate Field Expression - you will also need to use the UPDATEFIELD command or REGEN when populating Attributes with Fields.
i found this lisp of yours, but it is inserting a FIELD and not selecting...
i do not know how to modify this one...
(defun c:addnme (/ doc spc pt)
 (vl-load-com)
 (setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object))
       spc (if (zerop (vla-get-activespace doc))
             (if (= (vla-get-mspace doc) :vlax-true)
               (vla-get-modelspace doc)
               (vla-get-paperspace doc))
             (vla-get-modelspace doc)))
 (if (setq pt (getpoint "\nSelect Point for Field: "))
   (vla-AddMText spc
     (vlax-3D-point pt) 0 "%<\\AcDiesel $(getvar,dwgname)>%"))
 (princ))
A simplified example
(setq obj (vlax-ename->vla-object (car (entsel "\nPick text or mtext "))))
(vla-put-textstring obj "%<[url="file://\\AcDiesel"]\\AcDiesel[/url] $(getvar,dwgname)>%")
thanks for the assistance... I'd like to use fields instead of diesel
 (vl-load-com)
 ; (if (setq pt (getpoint "\nSelect Point for Field: "))
   ; (vla-AddMText spc
     ; (vlax-3D-point pt) 0 "%<[url="file://\\AcDiesel"]\\AcDiesel[/url] $(getvar,dwgname)>%"))
; (vla-put-textstring obj "%<[url="file://\\AcDiesel"]\\AcDiesel[/url] $(getvar,dwgname)>%")
(vla-put-textstring obj "%<\AcVar Filename \f "%tc1%fn2">%")
I'm getting an error :
Pick text or mtext ; error: Too many actual parameters
Just this a shot.
(defun c:Foo (/ pck)
 (and (setq pck (car (nentsel "\nPick Text/Mtext/Attribute :")))
      (or (wcmatch (cdr (assoc 0 (entget pck))) "TEXT,MTEXT,ATTRIB")
          (alert "Invalid object <!>"))
        (vla-put-textstring (vlax-ename->vla-object pck) "%<\\AcVar Filename \\f \"%fn2\">%")
        (vla-regen (vla-get-activedocument (vlax-get-acad-object)) Acactiveviewport)
) (vl-load-com)
Just this a shot.
) (vl-load-com)
Works perfectly! Thank you so much Tharwat.
Can I ask for a little modification?
if the layer is locked, unlock it write the filename and lock it again...
Hope you get what i mean
Try this:
(defun c:foo (/ doc pck lck get)
 ;; 	Tharwat - Date: 13.Sep.2017		;;
 ;; Drawing name to field without extension	;;
        (setq doc (vla-get-activedocument (vlax-get-acad-object)))
        (if
          (eq 4
              (logand
                4
                (cdr (assoc 70
                            (setq get (entget (tblobjname
                                                "LAYER"
                                                (cdr (assoc 8 (entget pck)))
           (entmod (subst '(70 . 0) (setq lck (assoc 70 get)) get))
        (vla-put-textstring (vlax-ename->vla-object pck) "%<\\AcVar Filename \\f \"%fn2\">%" )
        (if lck (entmod (subst lck (assoc 70 get) get)))
        (vla-regen doc acactiveviewport)
) (vl-load-com)
  • Thanks 1
Perfect! Much appreciated.
Thank you!!!
Thank you!!!
You are welcome anytime.
NOTE: I did a minor mods after a minute of posting the codes so recopy the codes again to have the latest.
Noted. thanks.
  • 4 years later...
On 9/13/2017 at 4:31 PM, Tharwat said:
Try this:
        (if
          (eq 4
              (logand
                4
                (cdr (assoc 70
                                                "LAYER"
) (vl-load-com)
thanks for your great job
I have now started studying diesel and field. Your code is very helpful.
Usually in my work, I add unnecessary phrases to the file name.
such as revision no., date, or (updated) (working)..
so I add a command to apply only the necessary parts to the text.
by added a very small part of your lisp.
command
field_fullnamedwg = field name with .dwg extension.
field_fullname = same as original
field_customname = input start & end character number
field_fulldirectory = get full path
but i failed in field_parentdirectory = get parent directory name only.
since strlen works differently for each folder.
(defun c:field_fullnamedwg ( / a b )
 (setq a 1)
 (setq b 0)
 (sub:name a b)
(defun c:field_fullname ( / a b )
 (setq a 1)
 (setq b 4)
 (sub:name a b)
(defun c:field_customname ( / dwgname dwgnamelen a b )
 (setq dwgname (getvar 'dwgname))
 (setq dwgnamelen (strlen (getvar 'dwgname)))
 (princ "\n your full dwg name is = [ ")
 (princ dwgname)
 (princ " ]")
 (princ "\n total number of characters = ")
 (princ dwgnamelen)
 (setq a (getint "\n input start character number (from 1) = "))
 (setq b (- dwgnamelen (getint "\n input end character number (from 1) = ")))
 (sub:name a b)
(defun c:field_fulldirectory ( / a b )
 (setq a 1)
 (setq b 0)
 (sub:directory a b)
;| get parent directory only - failed
(defun c:field_parentdirectory ( / fulldir fulldirlen fulldirlist fulldirlistlen strcount index atom del parentdir parentlen a b c)
 (setq fulldir (vl-princ-to-string (lm:unformat (getvar 'dwgprefix) nil)))
 (princ "\n fulldir - ")
 (princ fulldir)
 (setq fulldirlen (strlen fulldir))
 (princ "\n fulldir length - ")
 (princ fulldirlen)
 (setq fulldirlist (LM:str->lst fulldir "\\"))
 (princ "\n fulldirlist - ")
 (princ fulldirlist)
 (setq fulldirlistlen (length fulldirlist))
 (princ "\n fulldirlistlen - ")
 (princ fulldirlistlen)
 (setq strcount 0)
 (setq index 0)
 (setq atom 0)
 (repeat fulldirlistlen
   (setq atom (strlen (vl-princ-to-string (nth index fulldirlist))))
   (setq strcount (+ strcount atom))
   (setq index (+ index 1))
 );end of repeat
 (princ "\n total list strcount without deli = ")
 (princ strcount)
 (setq del (- fulldirlen strcount))
 (princ "\n delimiter count = ")
 (princ del)
 (setq parentdir (nth (- fulldirlistlen 2) fulldirlist))
 (princ "\n parent directory = ")
 (princ parentdir)
 (setq parentlen (strlen parentdir))
 ;(princ (substr (substr (getvar 'dwgprefix) (- (- (+ strcount fulldirlistlen) parentlen) 1) (+ parentlen 2)) 1 parentlen))
 (setq a (- (- (+ strcount fulldirlistlen) parentlen) 1))
 ;(setq a (- (- (- directorylen count) del) 1))
 (setq b 2)
 (sub:directory a b)
;; String to List  -  Lee Mac
;; Separates a string using a given delimiter
;; str - [str] String to process
;; del - [str] Delimiter by which to separate the string
;; Returns: [lst] List of strings
(defun LM:str->lst ( str del / pos )
    (if (setq pos (vl-string-search del str))
        (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del))
        (list str)
;by ronjonp https://www.theswamp.org/index.php?topic=44110.msg493609#msg493609
(defun _count (letter string)
  (length (vl-remove-if-not
            (function (lambda (x) (= (strcase letter) (strcase (chr x)))))
            (vl-string->list string)
(vl-load-com)
(defun sub:name ( a b / doc pck lck get stringtopaste)
        (if
          (eq 4
              (logand
                4
                (cdr (assoc 70
                                                "LAYER"
        (setq stringtopaste (strcat "%<\\AcDiesel $(substr,$(getvar,\"dwgname\")," (vl-princ-to-string a) ",$(-,$(strlen,$(getvar,\"dwgname\"))," (vl-princ-to-string b) "))>%"))
        (vla-put-textstring (vlax-ename->vla-object pck) stringtopaste)
(defun sub:directory ( a b / doc pck lck get stringtopaste)
        (if
          (eq 4
              (logand
                4
                (cdr (assoc 70
                                                "LAYER"
        (setq stringtopaste (strcat "%<\\AcDiesel $(substr,$(getvar,\"dwgprefix\")," (vl-princ-to-string a) ",$(-,$(strlen,$(getvar,\"dwgprefix\"))," (vl-princ-to-string b) "))>%"))
Thank you.
This should give you the Path only.
(vla-put-textstring (vlax-ename->vla-object pck) "%<\\AcVar Filename \\f \"%tc4%fn1\">%")
