subdVision Posted September 7, 2017 Posted September 7, 2017 Hi all, I came across a LISP routine that freezes the layer of any selected object. It works great but I want it to viewport freeze layers, not freeze for the entire drawing. This is where I found it: http://forums.augi.com/showthread.php?78426-Special-Layer-Freeze-LISP-Routine and this is the code I'd like to have modified: (the code wrap button doesn't seem to work) (defun c:LFR (/ CLayer$ EntList@ EntName^ Layer$)(setq CLayer$ (getvar "CLAYER")) (princ "\nSelect object on layer to freeze") (if (setq EntName^ (car (entsel))) (progn (setq EntList@ (entget EntName^)) (setq Layer$ (cdr (assoc 8 EntList@))) (if (and (= Layer$ CLayer$)(/= Layer$ "0")) (command ".LAYER" "T" "0" "U" "0" "ON" "0" "S" "0" "") );if (if (= Layer$ "0") (princ "\nCannot freeze layer 0.") (command ".LAYER" "F" Layer$ "") );if );progn );if (princ));defun c:LFR[code] I also attached the actual .LSP file to make it easier. LFR.LSPFetching info... Quote
