I have a problem with the UCS icon. In all my drawings if I right click on the UCS icon I do not get its shortcut menu. True I can access most of it thru the command line but still... the other problem possibly related is that if I move it, rotate it or do anything using its grips i can only do it once after I have done one change it becomes unselectable. If I close then drawing saving it first then reopen it I get one more move before it happens again and I have to reopen the drawing again each time I want to make any change to the UCS.
Anybody have any ideas?
I don't use 2018, but what you are describing certainly sounds like a bug, I doubt very much if it is a variable setting issue.
As it is hard to imagine anybody opting to have it behave/misbehave thusly.
In 2013 I can manipulate the UCS icon as much as I want
What have you done so far to troubleshoot the problem?
Not sure where to start troubleshooting this problem. I didn't have this problem with 2015LT and I come here as your tag says "seeking knowledge" when i don't know how to do something.
Did you install the service pack for 2018?
Did you try resetting AutoCAD system settings to their default?
