Please help to me create auto lisp for wiring attached below picture.this is socket outlet wiring wiring.jpg
Please help to me create auto lisp for wiring attached below picture.this is socket outlet wiring [ATTACH]61979[/ATTACH]
a bit similar like dynamic array command? (as seen in youTube)
but not sure ac2012?
no respond due to it's weekend or "please help to do something.."?
i'm not electrical related , in ac2007 something like command MEASURE with aligned block
You need two routines straight and corner, drawing a pline is feasible between 2 pick points. I would do a always clockwise as it saves a pick wire direction and you get used to it. Do not have anything at moment some else may have this done. Interesting why does the wire go through the room or is implying up and over in the walls in this case a 3rd option.
  • 2 weeks later...
