When generating a 2D elevation or Section it generates a block where all lines are with same color and width and type.
1. Is it possible to control these lines according to the element (e.g. a certain line for doors and another for windows and walls and so on).
2. Is it possible to control the amount of included lines based on the distance between lines - in many cases I see many adjacent lines, this is the case especially with rails.
Thanks a lot.
Just to be clear, you are asking in reference to AutoCAD Architecture, an AutoCAD vertical product, not plain AutoCAD. Correct?
Autocad Architecture
Actually I've updated the 2d Elevation Style and changed some subdivisions - I managed to change the 2D elevation output but it was not what I expected (it changed all the elevation - I could not change a certain object within the elevation output).
