Hello,
Does anyone know of a LSP out there that will number the selection below properly without editing each piece of text?
Also, anyone know if a way where you could rotate the entire selection by 90 degrees and the text rotates with it? Would want that as a totally separate LSP if possible. thanks!
To create an array and increment each number then look at Lee Macs INCARRAY lisp and INCARRAYD
as for your second question, I depends how many times you need to do this, I would just rotate it and use the properties menu to set the text rotation.. but there might be a smart way to do all that in one go
Not what I was looking for but thanks for the response.
I am looking for a LISP where I select all the text objects and it can order them from the first number to the last text object in increments of one. I do not like arrays.
Here's another:
(defun c:number	(/ i s)
 (setq i 0)
 (if (and (setq s (ssget ":L" '((0 . "text")))))
   (foreach e
     (vl-sort (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
	      '(lambda (a b) (> (caddr (assoc 10 (entget a))) (caddr (assoc 10 (entget b)))))
     (entmod (append (entget e) (list (cons 1 (itoa (setq i (1+ i)))))))
If you use annotative text an option is set angle to view so if you rotate what you have the text will rotate back to horizontal.
