Hello,
My manager made this LSP file for me and it doesn't work and we are both not sure why. Seems correct to me.
How it works: Creates the E-Anno-Note layer, otherwise makes it current, then creates an MLeader (to avoid creating leaders on incorrect layers).
(DEFUN C:NN ()
 (setvar "cmdecho" 0)
 (if (not (tblsearch "layer" "E-Anno-Note"))
   (command "-layer" "n" "E-Anno-Note" "c" "2" "E-Anno-Note" ""))
 (command "-layer" "m" "E-Anno-Note")
 (COMMAND "mleader")
Thanks!
Hi,
Need to add double quotes.
(command "-layer" "m" "E-Anno-Note" [color="magenta"][b]""[/b][/color])
  Tharwat said:
Hi,
(DEFUN C:mm ()
 command "-layer" "m" "E-Anno-Note" "")
 (COMMAND "mleader" "")
Still doesn't work when I run this...
You have omitted one bracket before the command call.
The -layer N is new, M is make new and make current, so does two steps.
So a slight variation
   (command "-layer" "m" "E-Anno-Note" "c" "2" "E-Anno-Note" "")
   (command "-layer" "s" "E-Anno-Note" "")
also
   (command "-layer" "m" "E-Anno-Note" "c" "2" "E-Anno-Note" ""))
   (setvar 'clayer "E-Anno-Note")
Thanks for the help. This works now.
Could I make it also adjust the settings of the MLeader before it is drawn so that it will make the right alignment in the middle of the bottom row of text (this is a standard CAD thing that doesn't seem to be the default).
Thanks in advance.
Thanks in advance.
You could add something like this to the code:
(if (setq e (dictsearch (namedobjdict) "ACAD_MLEADERSTYLE"))
 (progn (setq o (vlax-ename->vla-object
	   (cdr (assoc -1 (dictsearch (cdr (assoc -1 e)) (getvar 'cmleaderstyle))))
 (vla-put-textleftattachmenttype o 5)
 (vla-put-textrightattachmenttype o 5)
Anyone know of any way I can import an MLeader style right before it starts drawing the MLeader?
Make a template and insert it if the mleaderstyle does not exist.
I will try this with my manager and see if it works. Thanks!
I was able to adjust the leader in the style, but will this code locate the style on my computer or how does that work?
It just changes the current mleader style ( which might actually be bad practice ) ... I would check if the style exists and set it current, else import ( or create with code ) and set current.
Here is my updated code. Can anyone add some code so that it will import the MLeaderStyle before making the MLeader? Our style is called "Ascent"
(DEFUN C:mm ()
 (command "-layer" "m" "E-Anno-Note" "")
 (command "-layer" "c" "2" "E-Anno-Note" "")
 (command "-layer" "ps" "style_1" "E-Anno-Note" "")
 (COMMAND "mleader")
Actually, it looks like we need to create this MLeader style every time and set it to current if it doesn't exist...
