BIGAL Posted September 23, 2017 Share Posted September 23, 2017 (edited) This may be an alternative method the idea is it will work with any block in a layout has no limit on the number of atts updated 1 -> all. Rather than use tag name uses attribute creation order. It is written to read a file input as that wa sthe original post request but could be changed for a more user version when making the paired list of attribute order and new value. Either as a dcl entry I am pretty sure I have that. (ah:blockupdater lst) where lst is ((1 "BT Group LLC")(2 "Job Name")( 3 "BT") ( 12 "9/13/17")) etc ; a universal block attribute updater allows for input from file. ; By Alan H 2017 (defun ah:blockupdater ( / newline bname ) (setq fo (open "c:\\temp\\blkupdate.txt" "R")) (setq 1stline (read-line fo) ) ; 1st line Model or Layouts (setq bname (read-line fo) ) ; block name ; make a list of pairs position and new variable (setq lst '() ) (while (setq newline (read-line fo)) (setq x (vl-string-search "," newline)) (setq pos (substr newline 1 x)) (setq newval (substr newline (+ x 2))) (setq lst (cons pos lst)) (setq lst (cons newval lst)) ) (setq lst (reverse lst)) (close fo) ; other criteria ? (cond ((= "MODEL" (strcase 1stline)(do-model-blocks)) ((= "LAYOUTS" (strcase 1stline))(do-layout-blocks)) ) ) ;defun (defun do-model-blocks ( / ss) (setvar 'ctab "Model") (setq ss (ssget "x" (list (cons 0 "INSERT") (cons 2 bname)(cons 410 "Model")))) (ah:attup) ) (defun do-layout-blocks ( / doc lay plotabs len tabname x y z ss) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vlax-for lay (vla-get-Layouts doc) (setq plotabs (cons (vla-get-name lay) plotabs)) ) (repeat (length plotabs) (setq tabname (nth x plotabs)) (if (/= tabname "Model") (progn (setvar "ctab" tabname) (setq ss (ssget "x" (list (cons 0 "INSERT") (cons 2 bname)(cons 410 tabname)))) (ah:attup) ) ) ) ) (defun ah:attup ( / x y z) (repeat (setq x (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1))) ) ) (setq atts (vlax-invoke obj 'getattributes)) (setq z 0) (repeat (setq y (/ (length lst ) 2 )) (vla-put-textstring (nth (atoi (nth z lst)) atts) (nth (+ z 1) lst)) (setq z (+ z 2)) ) ) ) (princ) (ah:blockupdater) file data Layouts Myblockname 1,alan 4,FRED 6,asdf Edited September 24, 2017 by BIGAL Quote Link to comment Share on other sites More sharing options...
