Let’s say you have DWG title block template file, “DAY” with attributes tagged, “B” and “C”. You also have XLSX file, “CAL” with column A rows, (1 thru 7), column B rows, (ONE thru SEV) and column C rows, (SUN thru SAT). How do you use any programing method to create 7 drawings automatically using the template and the worksheet, numbered sequentially so that file “6.dwg” would contain title block displaying “SIX” and “FRI”? Thank You in advance. If I may be any more specific, please ask.
If you do a bit of searching here I posted some code using Getexcel.lsp this allows both ways autocad -> excel -> autocad.
You can save a variable using setenv this is saved on your computer, using a "Script" you can run a lisp that creates new dwg but uses the correct row for the info.
I am pretty sure there is numerous examples here about read excel and populate a title block.
This is maybe what your script would look like, you will need to create the enviroment variable only once then it can be changed any time. (setenv "Mytitle" 1)
New mydwt
(load "My title updator")
saveas dwgname
close
New mydwt
(setenv "Mytitle" 2)
saveas dwgname
close
New mydwt
(setenv "Mytitle" 3)
saveas dwgname
close
