bmartinez Posted August 1, 2017 Posted August 1, 2017 I need a script that will convert multiple DWG files to ONE single PDF file,I found one that does convert the dgw file but to single pdfs , im also having some issues with DWG files that are "read only" wont convert them but all my files i need to convert to pdf are READ ONLY. Quote
maratovich Posted August 2, 2017 Posted August 2, 2017 Options: 1. You need to use the publication, team _publish 2. Open the drawing and start the normal printing. Select the print area, print settings, specify the printer and print. Or do you have many frames in one model? Quote
BIGAL Posted August 2, 2017 Posted August 2, 2017 You can use a program called ghostscript it can join multiple pdf's into 1 pdf, we do this where we plot all layouts to an individual pdf and then lastly also save as one. You will need to down load ghostscript seperately. GETVALS3.lsp plotA3Pdfrange2.lsp Quote
