zyad Posted August 13, 2017 Posted August 13, 2017 Here's a quick way to make the radius tray ( no error checking on input ) (defun _makeradtray (w h r p) (entmake (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(67 . 0) '(8 . "E-PWER-CABL-TRAY") '(100 . "AcDbPolyline") '(90 . '(70 . 1) '(43 . 0) '(38 . 0) '(39 . 0) (cons 10 p) (cons 10 (setq p (list (+ w (car p)) (cadr p)))) '(42 . 0.414213562373095) (cons 10 (setq p (list (+ r (car p)) (- (cadr p) r)))) (cons 10 (setq p (list (car p) (- (cadr p) h)))) (cons 10 (setq p (list (- (car p) (+ w (* 2. r))) (cadr p)))) (cons 10 (setq p (list (car p) (+ (cadr p) h)))) '(42 . 0.414213562373095) (cons 10 (setq p (list (+ r (car p)) (+ (cadr p) r)))) ) ) ) (_makeradtray (getdist "\nEnter Width: ") (getdist "\nEnter Height: ") (getdist "\nEnter Radius: ") (getpoint "\nPick a point to place the tray: ") ) Hi,I am already modify your code to be hatched but I am stuck in rotate hatch and polyline can you modify it thanks for help. (command "_.hatch" "ANSI31" "0.0" "0.0" "_l" "" "_.change" "_l" "" "_p" "_la" "E-PWER-CABL-HATCH" "") Quote
zyad Posted August 14, 2017 Posted August 14, 2017 Here's a quick way to make the radius tray ( no error checking on input ) (defun _makeradtray (w h r p) (entmake (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(67 . 0) '(8 . "E-PWER-CABL-TRAY") '(100 . "AcDbPolyline") '(90 . '(70 . 1) '(43 . 0) '(38 . 0) '(39 . 0) (cons 10 p) (cons 10 (setq p (list (+ w (car p)) (cadr p)))) '(42 . 0.414213562373095) (cons 10 (setq p (list (+ r (car p)) (- (cadr p) r)))) (cons 10 (setq p (list (car p) (- (cadr p) h)))) (cons 10 (setq p (list (- (car p) (+ w (* 2. r))) (cadr p)))) (cons 10 (setq p (list (car p) (+ (cadr p) h)))) '(42 . 0.414213562373095) (cons 10 (setq p (list (+ r (car p)) (+ (cadr p) r)))) ) ) ) (_makeradtray (getdist "\nEnter Width: ") (getdist "\nEnter Height: ") (getdist "\nEnter Radius: ") (getpoint "\nPick a point to place the tray: ") ) I'm all really modified your code to be hatched but I am stuck in rotate polyline and hatch can you modify please Thanks for help Quote
ronjonp Posted August 14, 2017 Posted August 14, 2017 (edited) Try this: (defun c:radtray (/ p) (defun _makeradtray (w h r p rot / doc e h) (if (setq e (entmakex (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(67 . 0) '(8 . "E-PWER-CABL-TRAY") '(100 . "AcDbPolyline") '(90 . '(70 . 1) '(43 . 0) '(38 . 0) '(39 . 0) (cons 10 p) (cons 10 (setq p (list (+ w (car p)) (cadr p)))) '(42 . 0.414213562373095) (cons 10 (setq p (list (+ r (car p)) (- (cadr p) r)))) (cons 10 (setq p (list (car p) (- (cadr p) h)))) (cons 10 (setq p (list (- (car p) (+ w (* 2. r))) (cadr p)))) (cons 10 (setq p (list (car p) (+ (cadr p) h)))) '(42 . 0.414213562373095) (cons 10 (setq p (list (+ r (car p)) (+ (cadr p) r) 0.0))) ) ) ) (progn (setq doc (vla-get-activedocument (vlax-get-acad-object))) (setq h (vlax-invoke (if (= (getvar 'cvport) 1) (vla-get-paperspace doc) (vla-get-modelspace doc) ) 'addhatch achatchobject "ANSI31" :vlax-true ) ) (vlax-invoke h 'appendouterloop (list (vlax-ename->vla-object e))) (vla-add (vla-get-layers doc) "E-PWER-CABL-HATCH") (vla-put-layer h "E-PWER-CABL-HATCH") (vlax-put h 'patternangle (getvar 'hpang)) (vlax-put h 'patternscale (getvar 'hpscale)) (vla-evaluate h) ) ) (if rot (mapcar '(lambda (x) (vlax-invoke x 'rotate p rot)) (list (vlax-ename->vla-object e) h)) ) ) (_makeradtray (getdist "\nEnter Width: ") (getdist "\nEnter Height: ") (getdist "\nEnter Radius: ") (setq p (getpoint "\nPick a point to place the tray: ")) (getangle "\nRotation angle: " p) ) (princ) ) (vl-load-com) Edited August 15, 2017 by ronjonp Quote
zyad Posted August 15, 2017 Posted August 15, 2017 Try this: (defun _makeradtray (w h r p / doc e h) (if (setq e (entmakex (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(67 . 0) '(8 . "E-PWER-CABL-TRAY") '(100 . "AcDbPolyline") '(90 . '(70 . 1) '(43 . 0) '(38 . 0) '(39 . 0) (cons 10 p) (cons 10 (setq p (list (+ w (car p)) (cadr p)))) '(42 . 0.414213562373095) (cons 10 (setq p (list (+ r (car p)) (- (cadr p) r)))) (cons 10 (setq p (list (car p) (- (cadr p) h)))) (cons 10 (setq p (list (- (car p) (+ w (* 2. r))) (cadr p)))) (cons 10 (setq p (list (car p) (+ (cadr p) h)))) '(42 . 0.414213562373095) (cons 10 (setq p (list (+ r (car p)) (+ (cadr p) r)))) ) ) ) (progn (setq doc (vla-get-activedocument (vlax-get-acad-object))) (setq h (vlax-invoke (if (= (getvar 'cvport) 1) (vla-get-paperspace doc) (vla-get-modelspace doc) ) 'addhatch achatchobject "ANSI31" :vlax-true ) ) (vlax-invoke h 'appendouterloop (list (vlax-ename->vla-object e))) (vla-add (vla-get-layers doc) "E-PWER-CABL-HATCH") (vla-put-layer h "E-PWER-CABL-HATCH") (vlax-put hatch 'patternangle (getvar 'hpang)) (vlax-put hatch 'patternscale (getvar 'hpscale)) (vla-evaluate hatch) ) ) ) (vl-load-com) (_makeradtray (getdist "\nEnter Width: ") (getdist "\nEnter Height: ") (getdist "\nEnter Radius: ") (getpoint "\nPick a point to place the tray: ") ) Hi,ronjonp thanks for help,but I need to rotate hatch,polyline after create as specific angle. Quote
ronjonp Posted August 15, 2017 Posted August 15, 2017 Hi,ronjonp thanks for help,but I need to rotate hatch,polyline after create as specific angle. Code modified above. Quote
