bluebravo Posted July 31, 2017 Share Posted July 31, 2017 I have created a dynamic block for CMU, and it works great except for one thing. Please see image below, and the attached dwg file containing the block. Goal: Remove the 'Custom' option from the Lookup drop-down. Thank you for your time, in advance! CMU_8IN.dwg Quote Link to comment Share on other sites More sharing options...
Dana W Posted August 1, 2017 Share Posted August 1, 2017 Here's the drawing, and how to do it in the block editor. CMU_8IN_MOD.dwg Quote Link to comment Share on other sites More sharing options...
bluebravo Posted August 2, 2017 Author Share Posted August 2, 2017 Dana, I appreciate your response, but I am not able to open your file. I have tried converting, with no success. Could you please reupload? I am using AutoCAD 2015, if that helps. Thanks! Quote Link to comment Share on other sites More sharing options...
Dana W Posted August 2, 2017 Share Posted August 2, 2017 Dana, I appreciate your response, but I am not able to open your file. I have tried converting, with no success. Could you please reupload? I am using AutoCAD 2015, if that helps. Thanks! I saved and uploaded it as 2013. I'm sorry, I deleted the file last night. I can't re-do right now. Just follow the instructions I posted. It's apple pie simple. Make a play around copy of your drawing if you don't already have one, and give it a go with that. Quote Link to comment Share on other sites More sharing options...
