ElCidCampeador Posted July 25, 2017 Posted July 25, 2017 I'm trying to write a VBA code that searches in a general drawing all lines that have a specific length and slope. Then, every time it finds that line in the drawing, it will write next to a specific text, for example "line". Do you think it's possibile? Any idea? Thanks Quote
Tyke Posted July 25, 2017 Posted July 25, 2017 In principle what you want to do is perfectly possible. You search the current drawing filtering on lines to create a selection set. Then loop through the selection set and write your text at your desired position. Quote
BIGAL Posted July 26, 2017 Posted July 26, 2017 As VBA Dim FilterDXFCode(0) As Integer Dim FilterDXFVal(0) As Variant FilterDXFCode(0) = 0 FilterDXFVal(0) = "LINE" Set SS = ThisDrawing.SelectionSets.Add("Linelens") SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal For Cntr = 0 To SS.Count - 1 'now get the length etc and do something As lisp (setq ss (ssget (list (cons 0 "Line")))) (repeat (setq x (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1))))) (vla-get-length obj) (princ "\n") ) Quote
maratovich Posted July 26, 2017 Posted July 26, 2017 Do you think it's possibile? Can. Write all the requirements, and attach an example. Quote
BIGAL Posted July 27, 2017 Posted July 27, 2017 What worked ? You dont have to post the code just how, others may want the same answer. Quote
