bolton78 Posted January 14, 2009 Posted January 14, 2009 I am in the process of design a machine,but i have come across i little problem,which probably one of you will find very easy.but i am avit stuck I got a shaft going though a piece of box section which has a spocket and a pulley,which are driven by the shaft,but the problem im getting is what kind of arrangement will be best in this case? Bearing? and housing? how to hold the shaft in place? temp.dwg Quote
darn-net Posted January 14, 2009 Posted January 14, 2009 Try this out. There are 2 options. wasn't sure which way belts and chains were going. temp-2-options.dwg "Most of what I know came from the "F1" key" Quote
darn-net Posted February 20, 2009 Posted February 20, 2009 So how did this project turn out? Dave Quote
Strix Posted February 21, 2009 Posted February 21, 2009 I've changed your thread title you get a much better response if you use descriptive titles on this forum Quote
bolton78 Posted February 21, 2009 Author Posted February 21, 2009 I ended up using skf flanged plumber blocks at either side of box side,dunno how good it is yet,its still the process of being fab'd up and built Quote
