samifox Posted July 20, 2017 Share Posted July 20, 2017 Beginner - Revit coordinate system How Revit handle coordinates? For example i want the object to be in 0,0 so when i export it to autocad i want it to be in the UCS 0,0. How does it work? Quote Link to comment Share on other sites More sharing options...
halam Posted July 20, 2017 Share Posted July 20, 2017 Long and complex story. There have bee written some Insights by various people. Google it! ;-) Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 20, 2017 Share Posted July 20, 2017 This is the hardest thing for AutoCAD converts to fathom in Revit. Once you master it, you realize how intuitive and simple it is. But as Halam has already mentioned it's long and complex. Here's a good start, happy reading! http://revitoped.blogspot.com/2012/05/shared-coordinate-post-summary.html Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 21, 2017 Share Posted July 21, 2017 Beginner - Revit coordinate system How Revit handle coordinates? For example i want the object to be in 0,0 so when i export it to autocad i want it to be in the UCS 0,0. How does it work? In a collaborative environment, a properly set-up model may not export the way you want. Forget about changing the model to suit export needs like that unless you are doing it to a copy of the model. Just change it in AutoCAD to suit. Quote Link to comment Share on other sites More sharing options...
halam Posted July 21, 2017 Share Posted July 21, 2017 I wouldn't do that. a. what good is Revit if you still need AutoCAD ? b. For working with (future) dwg data from others c. Building designs, 'bim' if you like, NEEDS to be associated to real coordinate system for Coordination purposes with stakeholders (eg working with gis data and As Built delivery) Quote Link to comment Share on other sites More sharing options...
samifox Posted July 23, 2017 Author Share Posted July 23, 2017 hi in my area, Revit is a new girl in town, more than 90% of the people i work with using Autocad dwg. so using Autolisp to utilize Revit > dwg to specific client's standards is needed. i dont get, every object drawn in revit is actually 0.0. so there is no coordinate system? Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 23, 2017 Share Posted July 23, 2017 Have you tried exporting both from the Project Base Point and the Survey Point of a Revit project? Have you seen what the project coordinates show in Revit? There is a coordinate system, just not like AutoCAD. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 29, 2017 Share Posted July 29, 2017 so using Autolisp to utilize Revit > dwg to specific client's standards is needed. There is no LISP in Revit. If the project requires AutoCAD to a specific standard, use the right tool for the job, AutoCAD. Doing it in Revit and then exporting to .dwg is going to create headaches and a lot of unnecessary overhead. Quote Link to comment Share on other sites More sharing options...
